[MAPSERVER-USERS] Displaying population density with Mapserver
Pierre-Benoit Besse
besse.pb at gmail.com
Wed May 28 05:11:05 EDT 2008
Well, I confess, I'm new to GIS applications and I do not know a lot about
projections.
I understand I have to tell MapServer what is the projection of each layer I
use in the mapfile, but using ogrinfo on my shapefiles tells me that :
Layer name: pop_density
Geometry: Point
Feature Count: 249937
Extent: (-180.000000, -56.000000) - (179.750000, 83.500000)
*Layer SRS WKT:
(unknown)*
latitude: Real (24.15)
longitude: Real (24.15)
densite: Real (24.15)
I generated this shapefile from a CSV file with 3 columns : latitude,
longitude, density_value.
Did I have to define a projection then ? How do I do that ?
Best regards,
Faldor
2008/5/27 Fawcett, David <David.Fawcett at state.mn.us>:
> Have you defined an output projection for your map and input projections
> for each of your layers? It is likely that MapServer needs to know what the
> input projection/SRS is before it can translate to different units.
> David.
> -----Original Message-----
> *From:* Pierre-Benoit Besse [mailto:besse.pb at gmail.com]
> *Sent:* Tuesday, May 27, 2008 11:26 AM
> *To:* Fawcett, David
> *Cc:* Ritesh Ambastha; mapserver-users at lists.osgeo.org
> *Subject:* Re: [MAPSERVER-USERS] Displaying population density with
> Mapserver
> Ha, well, I prefer that :) I would need a lot of layer definitions to
> obtain something ok...
> But I just tried the "ground units" stuff, I tried with a 50 kilometers
> wide square and it drew squares the size of ASIA !! oO
> I had to define a 1 feet wide square to obtain something more or less ok...
> Does anybody know why ?
> Aside from that It seems to work, thank you !
> I will try the scalesymbol stuff tomorrow.
> Regards
>> Before you create lots of different layers to simulate symbol scaling,
>> you may want to try something else. It has been a long time since I
>> have played with scaled symbols, but give it a try.
>> You should be able to scale the symbols by setting a SYMBOLSCALE in the
>> LAYER object. This is the scale at which you want the symbol to appear
>> at the SIZE stated in the map file.
>> You may want to modify STYLE MAXSIZE if you think that you will want
>> your symbols to be larger than 50 pixels.
>> Another completely different approach that just came to my mind would be
>> to use ground units (e.g. meters) to set the size of your symbol. To do
>> this, set LAYER SIZEUNITS to meters. Calculate the size of a symbol in
>> meters on the ground that will touch adjacent symbols, or give you the
>> desired amount of space between the symbols. That way, the symbols
>> should scale consistently.
>> David.
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ritesh
>> Ambastha
>> Sent: Tuesday, May 27, 2008 10:16 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: Re: [MAPSERVER-USERS] Displaying population density with
>> Mapserver
>> Dear Faldor,
>> Robert is absolutely right. You will have to make different LAYERS for
>> the same POINT layer. But, define MAX/MINSCALE for each Layer. Change
>> STYLE -> SIZE values in each of the layer. You are done !!
>> Cheers !
>> Ambastha
>> Faldor wrote:
>> > Yes, but I need them to adapt for different extents.
>> > For example, When I zoom out enough to see the world, I need them 1
>> > pixel wide (it's ugly otherwise), but when I zoom in I will need then
>> > 2 or 5 or even 30 pixels wide to cover all space.
>> > 2008/5/27 Ritesh Ambastha <group.ritesh at gmail.com>:
>> >> Dear Faldor,
>> >> <snip>What I need is to have the points grow to cover all space
>> >> available when I zoom in.</snip>
>> >> Do you mean that the size of points should grow? It can be done
>> >> easily by setting proper SIZE in the STYLE tag.
>> >> Regards,
>> >> Ambastha
>> >> Faldor wrote:
>> >> > Hi,
>> >> > Sorry for my first empty message.
>> >> > My problem is, I need to display population density with Mapserver.
>> >> > The data comes from GPWv3 and has a resolution of 15'. I converted
>> >> > it to a POINT Shapefile using ogr2ogr.
>> >> > At first when I display it on a world map it shows nicely. But when
>> >> > I
>> >> zoom
>> >> > in it begins to show separated points for each value in the
>> >> > shapefile. What I need is to have the points grow to cover all
>> >> > space available
>> >> when
>> >> I
>> >> > zoom in.
>> >> > Is there any mean to do it with Mapserver ? I did not find it in
>> >> > the mapfile reference.
>> >> > I don't know if I explained it well (I'm not english speaking). If
>> >> > you
>> >> do
>> >> > not understand something, please ask.
>> >> > Cordialy,
>> >> > Faldor
>> >> View this message in context:
>> >> http://www.nabble.com/Displaying-population-density-with-Mapserver-tp
>> >> 17492210p17492387.html
>> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> mapserver-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> http://www.nabble.com/Displaying-population-density-with-Mapserver-tp174
>> 92210p17492783.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080528/c122b2d4/attachment.html
