[mapserver-users] CGI variable substitution
Stephen Davies
sdc at sdc.com.au
Wed May 28 22:28:14 EDT 2008
Nope. pfilter works fine and the = goes through without issue.
Stephen
On Thursday 29 May 2008 11:44:04 Paul Spencer wrote:
> Not sure if this is related, but I am surprised that your example
> works because you have not escaped the = in your pfilter. I would
> have expected that pfilter would have been cut off just before
> client_id and you would have a new variable called client_id=70))
> Paul
> On 28-May-08, at 9:51 PM, Stephen Davies wrote:
> > I have been using variable substitution for ages without any
> > problems at all
> > but now need to make a change to add a new variable.
> > I just cannot make it work.
> > Presumably, I am doing something stupid but I cannot see what.
> > Can anybody please help.
> > My URL looks like this:
> > http://www.agua.com.au/benparts/map.html?map=/tmp/11_70.map&client=70&map
> >ext=140.5261724+-36.7067416+140.5485957+-36.6984975
> > &mre=-1296538.11+-4230140.65+62672.87+-2872042.86&pfilter=pid+in+
> > (select+probe.id+from+probe+where+logger_id+in+(select+id+from+logger
> > +where+client_id=70))
> > (plus a deal more filter definitions).
> > My map file looks like this:
> > LAYER
> > CONNECTIONTYPE postgis
> > NAME "probe"
> > DATA "geom from atp using unique id using SRID=4283"
> > CONNECTION "user=scldad dbname=benparts"
> > PROCESSING "CLOSE_CONNECTION=DEFER"
> > STATUS ON
> > TYPE POINT
> > FILTER (%pfilter%)
> > PROJECTION
> > "init=epsg:4283"
> > END
> > MAXSCALE 5000000
> > LABELITEM "temp"
> > CLASS
> > NAME "Air Temp (Right Click to select)"
> > STYLE
> > COLOR 255 255 0
> > SYMBOL 'circle'
> > SIZE 7
> > END
> > LABEL
> > MINDISTANCE 15
> > POSITION CR
> > SIZE SMALL
> > BACKGROUNDCOLOR 0 0 0
> > COLOR 255 255 0
> > FORCE TRUE
> > END
> > END
> > END
> > This works as I expect.
> > I now want to add a new filter by adding:
> > &ffilter=blah_blah to the URL
> > and a new layer with the same syntax as above (but with the new
> > filter) to the
> > map file.
> > Despite trying a number of variations on the theme, my PostgreSQL
> > log still
> > shows a generated command that included %ffilter% instead of the
> > substitution
> > value.
> > TIA,
> > Stephen Davies
> > This email is for the person(s) identified above, and is
> > confidential to
> > the sender and the person(s). No one else is authorised to use or
> > disseminate this email or its contents.
> > Stephen Davies Consulting Voice: 08-8177
> > 1595
> > Adelaide, South Australia. Fax: 08-8177
> > 0133
> > Computing & Network solutions. Mobile:0403
> > 0405 83
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
This email is for the person(s) identified above, and is confidential to
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
