[mapserver-users] CGI variable substitution
Paul Spencer pspencer at dmsolutions.ca
Wed May 28 22:14:04 EDT 2008
Not sure if this is related, but I am surprised that your example
works because you have not escaped the = in your pfilter.  I would
have expected that pfilter would have been cut off just before
client_id and you would have a new variable called client_id=70))
Paul
On 28-May-08, at 9:51 PM, Stephen Davies wrote:
> I have been using variable substitution for ages without any
> problems at all
> but now need to make a change to add a new variable.
> I just cannot make it work.
> Presumably, I am doing something stupid but I cannot see what.
> Can anybody please help.
> My URL looks like this:
> http://www.agua.com.au/benparts/map.html?map=/tmp/11_70.map&client=70&mapext=140.5261724+-36.7067416+140.5485957+-36.6984975
> &mre=-1296538.11+-4230140.65+62672.87+-2872042.86&pfilter=pid+in+
> (select+probe.id+from+probe+where+logger_id+in+(select+id+from+logger
> +where+client_id=70))
> (plus a deal more filter definitions).
> My map file looks like this:
>    LAYER
>      CONNECTIONTYPE postgis
>      NAME "probe"
>      DATA "geom from atp using unique id using SRID=4283"
>      CONNECTION "user=scldad dbname=benparts"
>      PROCESSING      "CLOSE_CONNECTION=DEFER"
>      STATUS ON
>      TYPE POINT
>      FILTER  (%pfilter%)
>      PROJECTION
>        "init=epsg:4283"
>      END
>      MAXSCALE 5000000
>      LABELITEM "temp"
>      CLASS
>        NAME       "Air Temp (Right Click to select)"
>        STYLE
>          COLOR        255 255 0
>          SYMBOL 'circle'
>          SIZE 7
>        END
>        LABEL
>          MINDISTANCE 15
>          POSITION CR
>          SIZE SMALL
>          BACKGROUNDCOLOR  0 0 0
>          COLOR  255 255 0
>          FORCE TRUE
>        END
>      END
>    END
> This works as I expect.
> I now want to add a new filter by adding:
> &ffilter=blah_blah to the URL
> and a new layer with the same syntax as above (but with the new
> filter) to the
> map file.
> Despite trying a number of variations on the theme, my PostgreSQL
> log still
> shows a generated command that included %ffilter% instead of the
> substitution
> value.
> TIA,
> Stephen Davies
> This email is for the person(s) identified above, and is
> confidential to
> the sender and the person(s).  No one else is authorised to use or
> disseminate this email or its contents.
> Stephen Davies Consulting                            Voice: 08-8177
> 1595
> Adelaide, South Australia.                             Fax: 08-8177
> 0133
> Computing & Network solutions.                       Mobile:0403
> 0405 83
> mapserver-users at lists.osgeo.org
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
