[mapserver-users] CGI variable substitution
Stephen Davies
sdc at sdc.com.au
Wed May 28 21:51:29 EDT 2008
I have been using variable substitution for ages without any problems at all
but now need to make a change to add a new variable.
I just cannot make it work.
Presumably, I am doing something stupid but I cannot see what.
Can anybody please help.
My URL looks like this:
http://www.agua.com.au/benparts/map.html?map=/tmp/11_70.map&client=70&mapext=140.5261724+-36.7067416+140.5485957+-36.6984975
&mre=-1296538.11+-4230140.65+62672.87+-2872042.86&pfilter=pid+in+(select+probe.id+from+probe+where+logger_id+in+(select+id+from+logger+where+client_id=70))
(plus a deal more filter definitions).
My map file looks like this:
LAYER
CONNECTIONTYPE postgis
NAME "probe"
DATA "geom from atp using unique id using SRID=4283"
CONNECTION "user=scldad dbname=benparts"
PROCESSING "CLOSE_CONNECTION=DEFER"
STATUS ON
TYPE POINT
FILTER (%pfilter%)
PROJECTION
"init=epsg:4283"
END
MAXSCALE 5000000
LABELITEM "temp"
CLASS
NAME "Air Temp (Right Click to select)"
STYLE
COLOR 255 255 0
SYMBOL 'circle'
SIZE 7
END
LABEL
MINDISTANCE 15
POSITION CR
SIZE SMALL
BACKGROUNDCOLOR 0 0 0
COLOR 255 255 0
FORCE TRUE
END
END
END
This works as I expect.
I now want to add a new filter by adding:
&ffilter=blah_blah to the URL
and a new layer with the same syntax as above (but with the new filter) to the
map file.
Despite trying a number of variations on the theme, my PostgreSQL log still
shows a generated command that included %ffilter% instead of the substitution
value.
TIA,
Stephen Davies
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
