[mapserver-users] International characters in text paramater
Espen Isaksen
espen.isaksen at gmail.com
Thu May 29 07:03:59 EDT 2008
Tried a bit more, and strange things happen. Sometimes Mapserver just
runs for a long time without creating a map. Other times it creates a
map, but the letters are totally wrong. When using 248 for ø I do not
get any text at all. Using 156 for æ I get this:
http://bildr.no/view/205560
Appreciate it if anybody knows why this happens.
Espen
2008/5/29 Espen Isaksen <espen.isaksen at gmail.com>:
> Didn't get it to work as it should.
> This works:
> TEXT "test"
> This does not work(no text at all in the map):
> TEXT "Lysløype"
> If we do this
> TEXT ("Lysløype")
> mapserver does not understand the ASCII value and prints it out
> exactly as typed.
> Espen
> 2008/5/28 Frode Wiseth Jørgensen <frodewj at gmail.com>:
>> Hi Espen
>> Try this:
>> TEXT "Lysløype"
>> FrodeWJ
>> 2008/5/28 Espen Isaksen <espen.isaksen at gmail.com>:
>>> Hi!
>>> Tried to find a answer to this but was unable to. I am trying to use
>>> Norwegian characters in the text parameter in the class object. I set
>>> "Text (Lysløype)" in the map file but this does not work. How can I do
>>> this correctly? Example follows:
>>> LAYER # Lysloype
>>> NAME Lysloype
>>> TYPE line
>>> STATUS default
>>> DATA bygg/lysloype
>>> MAXSCALE 20000
>>> TRANSPARENCY 80
>>> LABELMAXSCALE 2000
>>> CLASS
>>> STYLE
>>> COLOR 255 255 0 # Gul farge.
>>> SYMBOL "point_line"
>>> SIZE 4
>>> END
>>> STYLE
>>> SYMBOL "normal_line"
>>> SIZE 1
>>> END
>>> TEXT (Lysløpe)
>>> LABEL
>>> SIZE 7
>>> COLOR 255 255 255
>>> OUTLINECOLOR 100 100 100
>>> ANGLE follow
>>> POSITION cc
>>> TYPE truetype
>>> FONT Verdana_bold
>>> MINDISTANCE 1000000
>>> PARTIALS false
>>> END
>>> END
>>> END
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> +47 99 03 41 42
