[mapserver-users] Using SLD and WMS with data comming from postgres
Adrien Ducos
adrienducos at gmail.com
Thu May 29 12:12:33 EDT 2008
Hi I would like to use an SLD file linked to a wms layer comming from a
postgres query (using postgis).
In the SLD file I have rules that puts polygon colors according to an
attribute in my table the attribute data can be equal to 1,2,3,4,5,6,7 or 8.
and according to the value the polygon would be 1=red, 2=yellow, 1=blue etc.
I use a mapfile to retrieve the query:
Here is the layer part of the mapfile
LAYER
NAME "buildings"
TYPE POLYGON
STATUS OFF
CONNECTION "dbname=... user=... password=... host=..."
CONNECTIONTYPE postgis
DATA "the_geom_polygon from (select id_imm, max(the_geom_polygon) as
the_geom_polygon, MAX(id_building_type) as color FROM imm_type group by
id_imm) as t USING UNIQUE id_imm USING SRID = -1"
METADATA
"wms_name" "buildings"
"wms_server_version" "1.1.0"
"wms_format" "image/png"
"wms_exceptions_format" "application-vnd.ogc.se_inimage"
"wms_transparent" "false"
END
PROJECTION
"init=epsg:27582"
END
END
Then I call this layer via a webservice with the link of the sld :
http://www.mysite/wmsExportMap.php?REQUEST=GetMap&VERSION=1.1.0&SERVICE=WMS&LAYERS=fond_wms,buildings&SLD=http://www.mysite/sld/buildings.sld&bbox=600477.507312,2424357.1016,605865.696562,2426763.76972&width=450&height=260
in wmsExportMap.php I use $request = ms_newowsrequestobj(); to get a WMS map
via a web service.
When I do this query I get the map I want except the the SLD does not work
the sld looks like :
<sld:StyledLayerDescriptor version="1.0.0" xmlns:sld="
http://www.opengis.net/sld" xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="
http://www.w3.org/1999/xlink" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
<sld:NamedLayer>
<sld:Name>buildings</sld:Name>
<sld:UserStyle>
<sld:Name>Default Styler</sld:Name>
<sld:Title>Default Styler</sld:Title>
<sld:Abstract/>
<sld:IsDefault>1</sld:IsDefault>
<sld:FeatureTypeStyle>
<sld:Name>testStyleName</sld:Name>
<sld:Title>title</sld:Title>
<sld:Abstract>abstract</sld:Abstract>
<sld:FeatureTypeName>Feature</sld:FeatureTypeName>
<sld:SemanticTypeIdentifier>generic:geometry</sld:SemanticTypeIdentifier>
<sld:Rule>
<sld:Name>color1</sld:Name>
<sld:Abstract>Abstract</sld:Abstract>
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>color</ogc:PropertyName>
<ogc:Literal>1</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
<sld:PolygonSymbolizer>
<sld:Fill>
<sld:CssParameter name="fill">#ff0f13</sld:CssParameter>
</sld:Fill>
</sld:PolygonSymbolizer>
</sld:Rule>
<sld:Rule>
<sld:Name>color2</sld:Name>
<ogc:Filter>
<ogc:Literal>2</ogc:Literal>
</ogc:Filter>
<sld:Fill>
<sld:CssParameter name="fill">#ff9900</sld:CssParameter>
</sld:Fill>
</sld:Rule>
<sld:Rule>
If I set no condition parameters in my sld, however it works fine (but then
the buildings on my map are all of the same color) so I know the sld file is
well linked to the WMS file. in addition, then I link with the above sld, I
can see that postgres asks for the color field which is the propertyName I
want to use, but still the buildings don't get the desired color.
Does someone have some problems like this? Is it possible to do this kink of
things via mapserver?
Thanks in advance
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080529/88540745/attachment.html
