[mapserver-users] Regular Expressions with PostGIS
Mike Saunt
mikesaunt at gmail.com
Thu May 29 12:57:03 EDT 2008
Thanks Paul - I'll have to create a switch to identify...
Thanks for the prompt response...
2008/5/29 Paul Ramsey <pramsey at cleverelephant.ca>:
> Hilarity ensues, same issue being debated in another thread.
> In your case, no, there's probably no way around it. query is
> implemented as a FILTER, and filter gets passed directly to the
> underlying data store as SQL. The syntax for FILTER in shape files is
> mapserver specific, the syntax for PostGIS filter is PostgreSQL
> specific.
> Store all your data in postgis :)
> Or, more hackily, name your layers based on their storage type.
> pg_layer1, shp_layer2, etc.
> Sorry!
> P
> On Thu, May 29, 2008 at 9:24 AM, Mike Saunt <mikesaunt at gmail.com> wrote:
> > Hi All
> > We have an application that calls MapServer CGI from C# which creates
> > regular expressions for qitem (itemnquery etc) - basically when calling a
> > shape file all is good but not with PostGIS
> > uniqueid~'(a|A)(b|B)(c|C)123' = good for postgis
> > [uniqueid]=~/(a|A)(b|B)(c|C)123/ = bad for postgis (good for mapserver)
> > Does anyone know a way around - the calling app doesn't necessarily know
> > whether the base layer is PostGIS or OGR or Shape etc
> > Cheers
> > Mike
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080529/03c19596/attachment-0001.html
