[mapserver-users] Using SLD and WMS with data comming from postgres
Adrien Ducos adrienducos at gmail.com
Fri May 30 05:33:46 EDT 2008
Ok I found the error, it was on the sld itself: apparently mapserver can't
handle in the same rule a point symbolizer and a polygon symbolizer. So I
have to make 2 sld layers: one for my points and one for my polygons. It is
a pity since openlayers could handle this without any problem.
(there was no problem with the temp file since I gave a chmod access to all
users in this folder; but now I understand why I have so many temp files in
this directory).
On Fri, May 30, 2008 at 10:29 AM, Barend Kobben <kobben at itc.nl> wrote:
> Did you check the SLD TMP file problem (from the thread Re: "SLD ignored /
> External Graphic ignored)" see excerpt below)?
> ***snip***
> Using SLDs is dependent on the correct setting of the two settings
>  IMAGEPATH  -- where the mapserver software puts the SLD and other
> temporary
> files
>  IMAGEURL -- where the web browser and other http services pick them up.
> Setting these incorrectly, and more importantly their security setting
> incorrrectly, will normally give no problems, but when using SLDs (and also
> in other cases, eg. when chaining Mapserver to external WMS and WFS
> services), they will make MS malfunction, but SILENTLY (ie. No error
> messages).
> Eg. in our set ups of a WMS with external SLD they are set as follows:
> For  a *nix setup ( MacOSX) with Mapserver CGI 'behind'  Apache:
> WEB
>    IMAGEPATH "/Users/kobben/Sites/ms_tmp/"
>    IMAGEURL "http://localhost/~kobben/ms_tmp/<http://localhost/%7Ekobben/ms_tmp/>
>    METADATA
>       [all your web metadata...]
>    END #metadata
> END #web
> For a Win box with Mapserver CGI 'behind'  IIS:
>  IMAGEPATH "C:/tmp/ms_tmp/"
>  IMAGEURL "http://geoserver.itc.nl/ms_tmp/"
> The IMAGEPATh is a directory that is reacheable by Mapserver at this real
> location (in this case expressed as Unix BSD path on my MacOSX or as  UNC
> path on Win) and that has read & write access set  for the Mapserver
> process. Eg. on the Winbox it should have write access for the anonymous
> system service account under which Mapserver runs (usually something like
> SERVERNAME\IWAM_SERVERNAME).
> You can test this by seeing if files with names like) are being created
> when
> you request the WMS with external SLD. If they are the IMAGEPATH celarly
> works. Then test if you can point a browser to the IMAGEURL and pick up the
> tmp file. If that worsk the IMAGEURL is also OK. Now it should work...
> Hope this helps.
> Barend Köbben
> International Institute for Geo-Information
> Sciences and Earth Observation (ITC)
> PO Box 6
> 7500AA Enschede, The Netherlands
> +31 (0)53 4874253
> International Institute for Geo-Information Science and Earth Observation
> (ITC)
> Chamber of Commerce: 410 27 560
> E-mail disclaimer
> The information in this e-mail, including any attachments, is intended for
> the addressee only. If you are not the intended recipient, you are hereby
> notified that any disclosure, copying, distribution or action in relation to
> the content of this information is strictly prohibited. If you have received
> this e-mail by mistake, please delete the message and any attachment and
> inform the sender by return e-mail. ITC accepts no liability for any error
> or omission in the message content or for damage of any kind that may arise
> as a result of e-mail transmission.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080530/eff3fa1a/attachment.html
