[mapserver-users] Using SLD and WMS with data comming
from postgres
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri May 30 09:36:38 EDT 2008
Adrien Ducos wrote:
> Ok I found the error, it was on the sld itself: apparently mapserver
> can't handle in the same rule a point symbolizer and a polygon
> symbolizer. So I have to make 2 sld layers: one for my points and one
> for my polygons. It is a pity since openlayers could handle this without
> any problem.
oops, saw this e-mail after I sent the previous.
In Mapserver, a layer can only be of one geometry type. So I think It
makes sense that different types of symbolizers would not be applied to
the same layer. In you case if you have a point and a polygon layer, you
can still use one sld with 2 <NamedLayer> (which would correspond to
your 2 layers).
> (there was no problem with the temp file since I gave a chmod access to
> all users in this folder; but now I understand why I have so many temp
> files in this directory).
> On Fri, May 30, 2008 at 10:29 AM, Barend Kobben <kobben at itc.nl
> <mailto:kobben at itc.nl>> wrote:
> Did you check the SLD TMP file problem (from the thread Re: "SLD
> ignored /
> External Graphic ignored)" see excerpt below)?
> ***snip***
> Using SLDs is dependent on the correct setting of the two settings
> IMAGEPATH -- where the mapserver software puts the SLD and other
> temporary
> files
> IMAGEURL -- where the web browser and other http services pick them up.
> Setting these incorrectly, and more importantly their security setting
> incorrrectly, will normally give no problems, but when using SLDs
> (and also
> in other cases, eg. when chaining Mapserver to external WMS and WFS
> services), they will make MS malfunction, but SILENTLY (ie. No error
> messages).
> Eg. in our set ups of a WMS with external SLD they are set as follows:
> For a *nix setup ( MacOSX) with Mapserver CGI 'behind' Apache:
> WEB
> IMAGEPATH "/Users/kobben/Sites/ms_tmp/"
> IMAGEURL "http://localhost/~kobben/ms_tmp/
> <http://localhost/%7Ekobben/ms_tmp/>"
> METADATA
> [all your web metadata...]
> END #metadata
> END #web
> For a Win box with Mapserver CGI 'behind' IIS:
> IMAGEPATH "C:/tmp/ms_tmp/"
> IMAGEURL "http://geoserver.itc.nl/ms_tmp/"
> The IMAGEPATh is a directory that is reacheable by Mapserver at this
> real
> location (in this case expressed as Unix BSD path on my MacOSX or as
> UNC
> path on Win) and that has read & write access set for the Mapserver
> process. Eg. on the Winbox it should have write access for the anonymous
> system service account under which Mapserver runs (usually something
> like
> SERVERNAME\IWAM_SERVERNAME).
> You can test this by seeing if files with names like) are being
> created when
> you request the WMS with external SLD. If they are the IMAGEPATH celarly
> works. Then test if you can point a browser to the IMAGEURL and pick
> up the
> tmp file. If that worsk the IMAGEURL is also OK. Now it should work...
> Hope this helps.
> Barend Köbben
> International Institute for Geo-Information
> Sciences and Earth Observation (ITC)
> PO Box 6
> 7500AA Enschede, The Netherlands
> +31 (0)53 4874253
> International Institute for Geo-Information Science and Earth
> Observation (ITC)
> Chamber of Commerce: 410 27 560
> E-mail disclaimer
> The information in this e-mail, including any attachments, is
> intended for the addressee only. If you are not the intended
> recipient, you are hereby notified that any disclosure, copying,
> distribution or action in relation to the content of this
> information is strictly prohibited. If you have received this e-mail
> by mistake, please delete the message and any attachment and inform
> the sender by return e-mail. ITC accepts no liability for any error
> or omission in the message content or for damage of any kind that
> may arise as a result of e-mail transmission.
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
