Re: [mapserver-users] GDAL and SDE raster
Lucena, Ivan
ivan.lucena at pmldnet.com
Mon Nov 3 19:40:57 EST 2008
I don't have SDE to tell you the truth but I would suggest you to create a VRT version of your dataset and use the VRT on your map file. [ gdal_translate -of vrt /filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER replacement.vrt ]
> -------Original Message-------
> From: Liz Godwin <godwin.liz at gmail.com>
> Subject: [mapserver-users] GDAL and SDE raster
> Sent: Nov 03 '08 22:19
> Hey folks,
> We've been beating ourselves up over this problem and I'm not sure
> what to try next.
> We can't seem to connect to SDE for a raster using GDAL in mapserver.
> This is happening on Linux.
> snippit from mapfile:
> TYPE RASTER
> DATA "SDE:server,port:5151,sde,user,pass,schema.table,RASTER"
> when trying to draw a map, i get a seg fault. When trying a
> getFeatureinfo request, I get this error:
> /filepath/SDE:server,port:5151,sde,user: Image handling error. Unable to
> open file LayerName for layer
> `/filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER' does
> not exist in the file system, and is not recognised as a supported dataset
> name.
> ... fatal error.
> msRasterQueryByRect()
> Any ideas how I might start to debug this? I have DEBUG set to 5 in both
> the LAYER and MAP object in the map file.
> Thanks!
> Liz
> [LINK: compose.php?to=mapserver-users at lists.osgeo.org]
> [LINK: http://lists.osgeo.org/mailman/listinfo/mapserver-users]
