[mapserver-users] GDAL and SDE raster
Liz Godwin godwin.liz at gmail.com
Tue Nov 4 08:24:52 EST 2008
Thank you, but that option doesn't appear to work for Raster data types.
Liz
On Mon, Nov 3, 2008 at 7:40 PM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
> I don't have SDE to tell you the truth but I would suggest you to create a
> VRT version of your dataset and use the VRT on your map file. [
> gdal_translate -of vrt
> /filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER
> replacement.vrt ]
> >  -------Original Message-------
> >  From: Liz Godwin <godwin.liz at gmail.com>
> >  Subject: [mapserver-users] GDAL and SDE raster
> >  Sent: Nov 03 '08 22:19
> >  Hey folks,
> >  We've been beating ourselves up over this problem and I'm not sure
> >  what to try next.
> >  We can't seem to connect to SDE for a raster using GDAL in mapserver.
> >  This is happening on Linux.
> >  snippit from mapfile:
> >  TYPE RASTER
> >  DATA "SDE:server,port:5151,sde,user,pass,schema.table,RASTER"
> >  when trying to draw a map, i get a seg fault.  When trying a
> >  getFeatureinfo request, I get this error:
> >  /filepath/SDE:server,port:5151,sde,user: Image handling error. Unable to
> >  open file LayerName for layer
> >  `/filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER' does
> >  not exist in the file system, and is not recognised as a supported
> dataset
> >  name.
> >  ... fatal error.
> >  msRasterQueryByRect()
> >  Any ideas how I might start to debug this?  I have DEBUG set to 5 in
> both
> >  the LAYER and MAP object in the map file.
> >  Thanks!
> >  Liz
> >  _______________________________________________
> >  mapserver-users mailing list
> >  [LINK: compose.php?to=mapserver-users at lists.osgeo.org]
> >  [LINK: http://lists.osgeo.org/mailman/listinfo/mapserver-users]
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081104/fee291c7/attachment-0001.html
