[mapserver-users] SLD not rendered correctly
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Nov 12 13:14:08 EST 2008
Daniel,
I could confirm that http://trac.osgeo.org/mapserver/ticket/2548 was
still an issue in the current mapserver code. I have committed the fix
in the trunk and updated the bug. Please give it a try and let me know.
I will also possibility fix it in the 5.2.x branch so it will be
available for the upcoming release.
With this fix, I was able to use your example SLD and have the expected
result. Note that I did not so any testing with the 5.0.x release
Best Regards,
Daniel Degasperi wrote:
> Hello,
> the attached SLD should render a point layer with an outlinecolor (see
> stroke), unfortunately the stroke-color seems to overwrite the fill color.
> Images are attached. withoutsld.png would be the expected result,
> withsld.png is the actual result.
> Can anybody help me?
> I'm using MapServer 5.0.3 on Centos5 and the render client is OpenLayers.
> These tickets could be related:
> * http://trac.osgeo.org/mapserver/ticket/1887
> * http://trac.osgeo.org/mapserver/ticket/2548
> Regards, Daniel
> Daniel Degasperi
> Software Developer
> daniel.degasperi at r3-gis.com
> R3 GIS Srl
> Via Johann Kravogl 2
> I-39010 Merano - Sinigo (BZ)
> Tel. +39 0473 494949
> Fax. +39 0473 069902
> Web http://www.r3-gis.com
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
