[mapserver-users] SLD not rendered correctly
Daniel Degasperi daniel.degasperi at r3-gis.com
Tue Nov 25 06:15:37 EST 2008
Dear Assefa,
sorry for the delay. We tried the SVN-Version (Date 13/11/08) and the
issue seems to be solved. Thank you very much for your quick reaction.
Regards,
Daniel
Yewondwossen Assefa schrieb:
> Daniel,
>  I could confirm that http://trac.osgeo.org/mapserver/ticket/2548 was
> still an issue in the current mapserver code. I have committed the fix
> in the trunk and updated the bug. Please give it a try and let me
> know. I will also possibility fix it in the 5.2.x branch so it will be
> available for the upcoming release.
> With this fix, I was able to use your example SLD and have the
> expected result. Note that I did not so any testing with the 5.0.x
> release
> Best Regards,
> Daniel Degasperi wrote:
>> Hello,
>> the attached SLD should render a point layer with an outlinecolor
>> (see stroke), unfortunately the stroke-color seems to overwrite the
>> fill color.
>> Images are attached. withoutsld.png would be the expected result,
>> withsld.png is the actual result.
>> Can anybody help me?
>> I'm using MapServer 5.0.3 on Centos5 and the render client is
>> OpenLayers.
>> These tickets could be related:
>>     * http://trac.osgeo.org/mapserver/ticket/1887
>>     * http://trac.osgeo.org/mapserver/ticket/2548
>> Regards, Daniel
>>   Daniel Degasperi
>>   Software Developer
>>   R3 GIS Srl
>>   Via Johann Kravogl 2
>>   I-39010 Merano - Sinigo (BZ)
>>   Tel. +39 0473 494949
>>   Fax. +39 0473 069902
>>   Web  http://www.r3-gis.com
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
  Daniel Degasperi
  Software Developer
  R3 GIS Srl
