[mapserver-users] White screen after editing mapfile
"Constanze Blübaum"
cbluebaum at gmx.de
Thu Nov 13 10:01:33 EST 2008
Hello,
thanks for your response. I attatched the mapfile.
But I don´t think somethings wrong with the mapfile. Everything runs fine, then I delete the mapfile from the server and copy the same mapfile to the server again. Everything is identical, but the mapserver crashes.
Constanze
-------- Original-Nachricht --------
> Datum: Thu, 13 Nov 2008 09:22:37 -0500
> Von: "Burgholzer,Robert" <rwburgholzer at deq.virginia.gov>
> An: "Constanze Blübaum" <cbluebaum at gmx.de>, mapserver-users at lists.osgeo.org
> Betreff: RE: [mapserver-users] White screen after editing mapfile
> Gonna have to post the mapfile I think, otherwise it is hard to see what
> you are doing wrong.
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of "Constanze Blübaum"
> Sent: Thursday, November 13, 2008 8:57 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] White screen after editing mapfile
> Hello list,
> I´m very new to mapserver and all his tricks.
> I run a mapserver together with the pmapper software on a virtual server
> (1&1 in Germany) in Linux. For testing I load one shapefile into the map and
> everything runs fine. But when I try to edit the mapfile to show a second
> shapefile my screen is white and nothing happens.
> I copied the running file to the server and everything runs fine.
> To test, if my edits caused the crash, I deleted to mapfile from server
> and copied it to the server again. Even the file is the same as before (same
> contents, same savingdate, ...) the screen remains white and the mapserver
> does nothing.
> It´s a mystery.
> Has anyone the experience? Or can point me a way to solve this problem?
> Any suggestions are helpful.
> Thanks in advance
> Constanze
> Sensationsangebot nur bis 30.11: GMX FreeDSL - Telefonanschluss + DSL
> für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081113/0b84b609/stade_boden.obj
