[mapserver-users] White screen after editing mapfile
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Thu Nov 13 10:18:22 EST 2008
I'm sorry, I got the impression from your original posting that you were having trouble when adding a second shapefile to your map, thus I assumed your problem was with adding a second LAYER, or with the second shapefile. Now, it seems as if you are suggesting that simply editing the file, and making NO changes will cause a crash?
Perhaps you are running into a problem with Unix and Windows file types?
Please, more info,
What system did you create your "original" file on?
What system are you performing your edits on?
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: "Constanze Blübaum" [mailto:cbluebaum at gmx.de]
Sent: Thursday, November 13, 2008 10:02 AM
To: Burgholzer,Robert; mapserver-users at lists.osgeo.org
Subject: Re: RE: [mapserver-users] White screen after editing mapfile
Hello,
thanks for your response. I attatched the mapfile.
But I don´t think somethings wrong with the mapfile. Everything runs fine, then I delete the mapfile from the server and copy the same mapfile to the server again. Everything is identical, but the mapserver crashes.
Constanze
-------- Original-Nachricht --------
> Datum: Thu, 13 Nov 2008 09:22:37 -0500
> Von: "Burgholzer,Robert" <rwburgholzer at deq.virginia.gov>
> An: "Constanze Blübaum" <cbluebaum at gmx.de>, mapserver-users at lists.osgeo.org
> Betreff: RE: [mapserver-users] White screen after editing mapfile
> Gonna have to post the mapfile I think, otherwise it is hard to see what
> you are doing wrong.
> 804-698-4405
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of "Constanze Blübaum"
> Sent: Thursday, November 13, 2008 8:57 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] White screen after editing mapfile
> Hello list,
> I´m very new to mapserver and all his tricks.
> I run a mapserver together with the pmapper software on a virtual server
> (1&1 in Germany) in Linux. For testing I load one shapefile into the map and
> everything runs fine. But when I try to edit the mapfile to show a second
> shapefile my screen is white and nothing happens.
> I copied the running file to the server and everything runs fine.
> To test, if my edits caused the crash, I deleted to mapfile from server
> and copied it to the server again. Even the file is the same as before (same
> contents, same savingdate, ...) the screen remains white and the mapserver
> does nothing.
> It´s a mystery.
> Has anyone the experience? Or can point me a way to solve this problem?
> Any suggestions are helpful.
> Thanks in advance
> Constanze
> Sensationsangebot nur bis 30.11: GMX FreeDSL - Telefonanschluss + DSL
> für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
