[mapserver-users] ms4w (fastcgi) and oracle 10?
zach cruise
zachc1980 at gmail.com
Tue Nov 18 14:20:56 EST 2008
sql*plus returns this error:
ORA-06553: PLS-221: 'SDO_GEOM' is not a procedure or is undefined
06553. 00000 - "PLS-%s: %s"
*Cause:
*Action:
Error at Line:x Column:x
"select ID, GEOM from STATES" works though. i have oracle locator not
spatial, if that matters. also column GEOM is type SDO_GEOMETRY with
MDSYS.SPATIAL_INDEX.
On Tue, Nov 18, 2008 at 12:49 PM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> Have you checked that the SQL statement
> SELECT ID, GEOM FROM STATES WHERE SDO_FILTER(
> GEOM, MDSYS.SDO_GEOM(2003, 90112,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO
> _ORDINATE_ARRAY(-179,-89.5166667,179,83.5166667) ),'querytype=window')
> = 'TRUE'
> works from SQL*Plus or something else that you are using with your Oracle? If not, then investigate and adjust the DATA string accordingly.
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: zach cruise
> Lähetetty: ti 18.11.2008 19:44
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Kopio: Richard Polk; Smith,Michael ERDC-CRREL-NH
> Aihe: Re: [mapserver-users] ms4w (fastcgi) and oracle 10?
> thanks mike, but i get the same ora-xxxxx errors when using either:
> shp2img -m oracle.map -o oracle.png -all_debug 10
> msOracleSpatialLayerOpen called with: GEOM from STATES using unique ID
> srid 90112
> msOracleSpatialLayerOpen. Shared connection not available. Creating one.
> msConnPoolRegister(layername,username/password at databasename,019A68E8)
> msOracleSpatialLayerFreeItemInfo was called.
> msOracleSpatialLayerWhichShapes was called.
> msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data:
> SELECT ID, GEOM FROM STATES WHERE SDO_FILTER( GEOM,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-179,-89.5166667,179,83.5166667)
> ),'querytype=window') = 'TRUE'
> msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
> ORA-29900: operator binding does not exist
> ORA-06540: PL/SQL: compilation error
> ORA-06553: PLS-907: cannot load library unit MDSYS.SDO_3GL (referenced
> by MDSYS.SDO_FILTER)
> . Query statement: SELECT ID, GEOM FROM STATES WHERE SDO_FILTER(
> = 'TRUE' . Check your data statement.
> using 4.8 with /ignored-libmap/oracle10g/libmap.dll. how do i tell if
> i have native or ogr support for oracle 10g? i also edited httpd.conf
> (did i need to?) from
> http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto, but
> still no luck.
> On Tue, Nov 18, 2008 at 6:42 AM, Smith, Michael ERDC-CRREL-NH
> <Michael.Smith at usace.army.mil> wrote:
>> Zach,
>> Your DATA statement is almost correct. If you are going to use the UNIQUE
>> keyword (for supporting queries), you must put a column name after UNIQUE
>> and before the SRID.
>> Either of these would work:
>> DATA ' GEOM from STATES using UNIQUE ID srid 90112'
>> or
>> DATA ' GEOM from STATES using srid 90112'
>> Assuming you have a column named ID, of course.
>> Mike
>> Michael Smith
>> RSGIS Center
>> ERDC - CRREL
>> US Army Corps of Engineers
>> On 11/17/08 8:21 PM, "zach cruise" <zachc1980 at gmail.com> wrote:
>>> troubleshooting info on 4.8 box with /ignored-libmap/oracle10g/libmap.dll:
>>> msOracleSpatialLayerOpen called with: GEOMETRY from STATES using
>>> unique srid 90112
>>> msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error parsing
>>> OracleSpatial DATA variable. Must be:'geometry_column FROM table_name
>>> [USING UNIQUE <column> SRID srid# FUNCTION]' or 'geometry_column FROM
>>> (SELECT stmt) [USING UNIQUE <column> SRID srid# FUNCTION]'. If want to
>>> set the FUNCTION statement you can use: FILTER, RELATE, GEOMRELATE or
>>> NONE. Your data statement: GEOM from STATES using unique srid 90112
>>> On Mon, Nov 17, 2008 at 7:34 PM, zach cruise <zachc1980 at gmail.com> wrote:
>>>> btw i got oracle 10 client (with tnsnames.ora) on 4.8 box. other than
>>>> returning multiple ora-xxxx errors, 4.8 also returns "web template
>>>> error" if i use /ignored-libmap/oracle10g/libmap.dll. this error is
>>>> even for only shapefile maps. error goes away when i switch back to
>>>> normal libmap.dll.
>>>> On Mon, Nov 17, 2008 at 5:56 PM, zach cruise <zachc1980 at gmail.com> wrote:
>>>>> looks like mod_fastcgi is not an option with ms4w and oracle 10.
>>>>> anyway it had little benefits.
>>>>> i now got mapserver 5.2 and 4.8:
>>>>> i thought 5.2 had native built-in support for oracle 10, but it is
>>>>> giving me "OracleSpatial is not supported" error. i also thought 4.8
>>>>> could get ogr support for oracle 10 by following the steps on
>> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#oracle-10g>>>
>>>>> 4.8 connects, but returns multiple ORA-xxxx errors.
>>>>> so:
>>>>> do i have to install oracle 10 client locally and make changes to
>>>>> httpd.conf for 5.2 to work?
>>>>> how do i find correct srid for 4.8 to work? (DATA "GEOMETRY from
>>>>> (select GEOMETRY from STATES where NAME = 'New York')")
>>>>> any performance difference between native built-in and ogr supports?
>>>>> On Fri, Nov 14, 2008 at 6:22 PM, Jeff McKenna
>>>>> <jmckenna at gatewaygeomatics.com> wrote:
>>>>>> zach cruise wrote:
>>>>>>> does current ms4w with fastcgi work with oracle 10?
>>>>>>> here're warnings
>>>>>>> http://www.maptools.org/ms4w/?page=README_INSTALL.html#f-fastcgi
>>>>>>> http://www.nabble.com/fastcgi-connections-to-Oracle-and-SDE-on-Windows-to1
>>>>>>> 8394152.html
>>>>>>> in testing this was successful with PostgreSQL 8.3.1 / PostGIS 1.3.3,
>>>>>>> but unsuccessful with Oracle 10.2.0.1.0 (Apache logs: "mod_fcgid: get
>>>>>>> overlap result error")
>>>>>>> if not, any workarounds?
>>>>>> I tested and wrote that note...and am not aware of a workaround yet. You
>>>>>> should also send this question to the MS4W mailing list (subscribe at:
>>>>>> http://lists.maptools.org/mailman/listinfo/ms4w-users)
>>>>>> Jeff McKenna
>>>>>> FOSS4G Consulting and Training Services
>>>>>> http://www.gatewaygeomatics.com/
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
