[MAPSERVER-USERS] CLASSITEM and EXPRESSION issue in trunk?
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Nov 21 09:38:55 EST 2008
The PostGIS support underwent major changes recently so I'd suspect this
is specific
to that work. Perhaps there are character padding affecting things?
Steve
>>> Pål Kristensen <pal.kristensen at statkart.no> 11/21/08 8:36 AM >>>
Hi!
I've compiled 5.3-dev from trunk yesterday and got some trouble with
some
mapfiles that works well on 5.2. The problem is that the EXPRESSION
parameter in the CALSS object does not work with direct string
comparison.
Her are some examples:
Does NOT work: (This is the original layer definition from the 5.2
mapfile)
LAYER
CLASSITEM "maxhoyde"
CLASS
NAME "test"
EXPRESSION "600"
END
END
Using RegEx instead WORKS:
LAYER
CLASS
NAME "test"
EXPRESSION /600/
END
END
Using logical expression WORKS:
LAYER
#CLASSITEM "maxhoyde"
CLASS
NAME "test"
EXPRESSION ([makshoyde] == 600)
END
END
The data is stored in PostgreSQL (PostGIS), and the actual field type is
character(5). Anyone have a clue about what is causing this strange
behavior.
Regards,
Pål Kristensen
View this message in context:
http://www.nabble.com/CLASSITEM-and-EXPRESSION-issue-in-trunk--tp20622309p20622309.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
