[MAPSERVER-USERS] Debian Oracle10g OCI
dzizes451 at gmail.com
Tue Sep 16 05:00:30 EDT 2008
Thanks for the tip!
The Makefile looks like:
-------------- Compiler Info -------------
C compiler: gcc -O2 -fPIC -Wall
C++ compiler: g++ -O2 -fPIC -Wall
Debug:
Generic NINT:
-------------- Renderer Settings ---------
zlib support: -DUSE_ZLIB
png support:
palette rgba png support:
jpeg support:
iconv support: -DUSE_ICONV
AGG support:
AGG Freetype support:
Ming(flash) support:
PDFLib support:
-------------- Support Libraries ---------
Proj.4 support: -DUSE_PROJ
Libxml2 support:
FriBidi support:
Curl support: -DUSE_CURL
FastCGI support:
Threading support: -DUSE_THREAD
GEOS support:
-------------- Data Format Drivers -------
native tiff support:
PostGIS support:
EPPL7 support: -DUSE_EPPL
ArcSDE support:
OGR support: -DUSE_OGR
GDAL support: -DUSE_GDAL
Oracle Spatial support: -DUSE_ORACLESPATIAL
-------------- OGC Services --------------
WMS Server: -DUSE_WMS_SVR
WMS Client: -DUSE_WMS_LYR
WFS Server:
WFS Client: -DUSE_WMS_LYR
WCS Server:
SOS Server:
-------------- MapScript -----------------
PHP MapScript: no
the make command throws the following error:
warning: libnnz10.so, needed by
/usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so, not
found (try using -rpath or -rpath-link)
/usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so:
undefined reference to `nztSearchNZDefault'
undefined reference to `nzosCipherSpecToStr'
undefined reference to `nztwOpenWallet'
undefined reference to `A_X931RandomInit'
ends with
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
any ideas!
Michał
2008/9/16 Umberto Nicoletti <umberto.nicoletti at gmail.com>
> Usign tiff AND gdal is not recommended, you'd better try these options:
> ./configure
> -with-oraclespatial=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server
> -with-proj -with-wfsclient -with-wmsclient -with-gdal -with-ogr
> -with-threads -with-freetype -without-tiff -with-FastCGI
> as for the expat error:
> sudo apt-get install libexpat1 libexpat1-dev
> Umberto
> 2008/9/16 <dzizes451 at gmail.com>:
> > Hi again,
> > I've tried to compile mapserv executable with:
> > ./configure
> > -with-threads -with-freetype -with-tiff -with-FastCGI
> > and I receive this error:
> > /usr/bin/ld: cannot find -lexpat
> > Does anyone know what is wrong?
> > Michał
> > On Mon, Sep 15, 2008 at 3:16 PM, Dan Little <danlittle at yahoo.com> wrote:
> >> Umberto is right, for Mapserver to connect to Oracle you need to specify
> >> that capability at compile time. But for you ge tthat far I think you
> need
> >> to make sure that some of the basics work.
> >> Also, if you cannot connect to Oracle via SQL*Plus (assuming the binary
> is
> >> installed) you have other problems including but not limited to:
> >> - needing to set the LD_LIBRARY_PATH to include all the libraries. This
> >> may also need to be done in Apache while running mapserver to access
> Oracle.
> >> - needing to configure your TNSNAMES file.
> >> - check firewall setting in order to make sure you can connect on 1521
> (or
> >> whatever port you are using for Oracle).
> >> Generally, when running an Oracle layer, you want to try the following
> >> diagnostic steps:
> >> 1) Use SQL Developer to connect to the database (it has it's own drivers
> >> built in, so there's no software dependency issues). This will resolve
> >> whether or not the databas is working.
> >> 2) On the machine, try connecting with SQL Plus. This will determine
> >> whether or not you have your client configured correctly. Do not move
> on
> >> until this works.
> >> 3) Try and re-compile Mapserver with Oracle Spatial. At the end of the
> >> ./configure script there is an output screen, ensure that you see Oracle
> is
> >> turned on, otherwise scroll up in the screen and see what's missing.
> >> ----- Original Message ----
> >> > From: Umberto Nicoletti <umberto.nicoletti at gmail.com>
> >> > To: dzizes <dzizes451 at gmail.com>
> >> > Cc: mapserver-users at lists.osgeo.org
> >> > Sent: Monday, September 15, 2008 7:45:48 AM
> >> > Subject: Re: [MAPSERVER-USERS] Debian Oracle10g OCI
> >> > You have to recompile mapserver with the:
> >> > --with-oraclespatial=[path to oracle home]
> >> > option. That's all that is needed to enable oracle spatial support in
> >> > mapserver.
> >> > HTH,
> >> > Umberto
> >> > On Mon, Sep 15, 2008 at 2:05 PM, dzizes wrote:
> >> > > Hi,
> >> > > I've installed mapserver on Debian (lenny distribution). I've
> managed
> >> > > to
> >> > > create mapfile based on shp data and successfully send a wms request
> >> > > to get
> >> > > a map. I seems that mapserver works fine.
> >> > > I've also installed oracle-ex and I can connect to my Oracle via
> >> > > sqlplus.
> >> > > However, when I request wms (to a map file pointing to Oracle10g) I
> >> > > receive
> >> > > the following:
> >> > > msDrawMap(): Image handling error. Failed to draw layer named
> 'test'.
> >> > > msOracleSpatialLayerOpen(): OracleSpatial error. OracleSpatial is
> not
> >> > > supported
> >> > > I've found that I need OCI installed and configured properly, but
> >> > > there is
> >> > > no clear tutorial.
> >> > > Please provide me a some step by step guide.
> >> > > Greets,
> >> > > Michal
> >> > > View this message in context:
> >> > http://www.nabble.com/Debian-Oracle10g-OCI-tp19491636p19491636.html
> >> > > Sent from the Mapserver - User mailing list archive at Nabble.com.
> >> > > _______________________________________________
> >> > > mapserver-users mailing list
> >> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080916/ba0829f4/attachment-0001.html
