R: [MAPSERVER-USERS] Debian Oracle10g OCI
Leandro Dardini
l.dardini at comune.prato.it
Tue Sep 16 06:02:03 EDT 2008
I hate using the LD_LIBRARY_PATH trick. I think this is a work around for software developer to not take in to account different Linux software distribution.
If you have a Lenny, add a file into /etc/ld.so.conf.d with the list of directory where special oracle library resides.
Run ldconfig -v and check if library are correctly cached.
Now run ldd /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so and check if all needed library are available. If a library is missing, run "updatedb; locate <library>" and add the directory to the file in ld.so.conf.d directory. Repeat until all library are correctly defined.
Leandro
> -----Messaggio originale-----
> Da: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Per conto di
> Umberto Nicoletti
> Inviato: martedì 16 settembre 2008 11.55
> A: dzizes451 at gmail.com
> Cc: mapserver-users at lists.osgeo.org
> Oggetto: Re: [MAPSERVER-USERS] Debian Oracle10g OCI
> I'm at a complete loss here. I assume there is a problem with
> your oracle install.
> did you run /etc/init.d/oracle-xe configure?
> Umberto
> 2008/9/16 <dzizes451 at gmail.com>:
> > Makefile generates without any problems, but when executing make
> > command I
> > receive:
> > /usr/bin/ld: warning: libnnz10.so, needed by
> /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so,
> > not found (try using -rpath or -rpath-link)
> /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so:
> > undefined reference to `nztSearchNZDefault'
> > undefined reference to `nzosCipherSpecToStr'
> > undefined reference to `nztwOpenWallet'
> > undefined reference to `A_X931RandomInit'
> > undefined reference to `nzosgpc_GetProtocolVer'
> > undefined reference to `nzos_DisableClientAuthentication'
> > undefined reference to `nzduui2_destroy_ui'
> > ORACLE_HOME=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server
> LD_LIBRARY_PATH=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server/bi
> > n PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
> > LOGNAME=root
> > Michał
> > 2008/9/16 Umberto Nicoletti <umberto.nicoletti at gmail.com>
> >> Revert configure to the previous oraclespatial setting and try:
> >> export
> >> before configure.
> >> Umberto
> >> > Now I get:
> >> > checking if OracleSpatial support requested... yes, user
> supplied
> >> > ORACLE_HOME
> >> > configure: error: Oracle Spatial: libclntsh.so not found.
> >> > I enclose the config.log.
> >> > Michał
> >> >> try:
> >> >> -with-oraclespatial=/usr/lib/oracle/xe/app/oracle/product/10.2.0
> >> >> otherwise post the config.log file.
> >> >> Umberto
> >> >> > Thanks for the tip!
> >> >> > The Makefile looks like:
> >> >> > -------------- Compiler Info -------------
> >> >> > C compiler: gcc -O2 -fPIC -Wall
> >> >> > C++ compiler: g++ -O2 -fPIC -Wall
> >> >> > Debug:
> >> >> > Generic NINT:
> >> >> > -------------- Renderer Settings ---------
> >> >> > zlib support: -DUSE_ZLIB
> >> >> > png support:
> >> >> > palette rgba png support:
> >> >> > jpeg support:
> >> >> > iconv support: -DUSE_ICONV
> >> >> > AGG support:
> >> >> > AGG Freetype support:
> >> >> > Ming(flash) support:
> >> >> > PDFLib support:
> >> >> > -------------- Support Libraries ---------
> >> >> > Proj.4 support: -DUSE_PROJ
> >> >> > Libxml2 support:
> >> >> > FriBidi support:
> >> >> > Curl support: -DUSE_CURL
> >> >> > FastCGI support:
> >> >> > Threading support: -DUSE_THREAD
> >> >> > GEOS support:
> >> >> > -------------- Data Format Drivers -------
> >> >> > native tiff support:
> >> >> > PostGIS support:
> >> >> > EPPL7 support: -DUSE_EPPL
> >> >> > ArcSDE support:
> >> >> > OGR support: -DUSE_OGR
> >> >> > GDAL support: -DUSE_GDAL
> >> >> > Oracle Spatial support: -DUSE_ORACLESPATIAL
> >> >> > -------------- OGC Services --------------
> >> >> > WMS Server: -DUSE_WMS_SVR
> >> >> > WMS Client: -DUSE_WMS_LYR
> >> >> > WFS Server:
> >> >> > WFS Client: -DUSE_WMS_LYR
> >> >> > WCS Server:
> >> >> > SOS Server:
> >> >> > -------------- MapScript -----------------
> >> >> > PHP MapScript: no
> >> >> > the make command throws the following error:
> >> >> > h.so,
> >> >> > not
> >> >> > ends with
> >> >> > collect2: ld returned 1 exit status
> >> >> > make: *** [shp2img] Error 1
> >> >> > any ideas!
> >> >> > Michał
> >> >> >> Usign tiff AND gdal is not recommended, you'd better
> try these
> >> >> >> options:
> >> >> >> ./configure
> >> >> >> 0/server -with-proj -with-wfsclient -with-wmsclient
> -with-gdal
> >> >> >> -with-ogr -with-threads -with-freetype -without-tiff
> >> >> >> -with-FastCGI
> >> >> >> as for the expat error:
> >> >> >> sudo apt-get install libexpat1 libexpat1-dev
> >> >> >> Umberto
> >> >> >> > Hi again,
> >> >> >> > I've tried to compile mapserv executable with:
> >> >> >> > ./configure
> >> >> >> > 2.0/server -with-proj -with-wfsclient -with-wmsclient
> >> >> >> > -with-gdal -with-ogr -with-threads -with-freetype
> -with-tiff
> >> >> >> > -with-FastCGI
> >> >> >> > and I receive this error:
> >> >> >> > /usr/bin/ld: cannot find -lexpat
> >> >> >> > Does anyone know what is wrong?
> >> >> >> > Michał
> >> >> >> > On Mon, Sep 15, 2008 at 3:16 PM, Dan Little
> >> >> >> > <danlittle at yahoo.com>
> >> >> >> > wrote:
> >> >> >> >> Umberto is right, for Mapserver to connect to Oracle you
> >> >> >> >> need to specify that capability at compile time. But for
> >> >> >> >> you ge tthat far I think you need to make sure
> that some of
> >> >> >> >> the basics work.
> >> >> >> >> Also, if you cannot connect to Oracle via
> SQL*Plus (assuming
> >> >> >> >> the binary is
> >> >> >> >> installed) you have other problems including but
> not limited to:
> >> >> >> >> - needing to set the LD_LIBRARY_PATH to include all the
> >> >> >> >> libraries.
> >> >> >> >> This
> >> >> >> >> may also need to be done in Apache while running
> mapserver
> >> >> >> >> to access Oracle.
> >> >> >> >> - needing to configure your TNSNAMES file.
> >> >> >> >> - check firewall setting in order to make sure you can
> >> >> >> >> connect on
> >> >> >> >> 1521
> >> >> >> >> (or
> >> >> >> >> whatever port you are using for Oracle).
> >> >> >> >> Generally, when running an Oracle layer, you want
> to try the
> >> >> >> >> following diagnostic steps:
> >> >> >> >> 1) Use SQL Developer to connect to the database
> (it has it's
> >> >> >> >> own drivers built in, so there's no software dependency
> >> >> >> >> issues). This will resolve whether or not the databas is
> >> >> >> >> working.
> >> >> >> >> 2) On the machine, try connecting with SQL Plus.
> This will
> >> >> >> >> determine whether or not you have your client configured
> >> >> >> >> correctly. Do not move on until this works.
> >> >> >> >> 3) Try and re-compile Mapserver with Oracle
> Spatial. At the
> >> >> >> >> end of the ./configure script there is an output screen,
> >> >> >> >> ensure that you see Oracle is turned on,
> otherwise scroll up
> >> >> >> >> in the screen and see what's missing.
> >> >> >> >> ----- Original Message ----
> >> >> >> >> > From: Umberto Nicoletti <umberto.nicoletti at gmail.com>
> >> >> >> >> > To: dzizes <dzizes451 at gmail.com>
> >> >> >> >> > Sent: Monday, September 15, 2008 7:45:48 AM
> >> >> >> >> > Subject: Re: [MAPSERVER-USERS] Debian Oracle10g OCI
> >> >> >> >> > You have to recompile mapserver with the:
> >> >> >> >> > --with-oraclespatial=[path to oracle home]
> >> >> >> >> > option. That's all that is needed to enable
> oracle spatial
> >> >> >> >> > support in mapserver.
> >> >> >> >> > HTH,
> >> >> >> >> > Umberto
> >> >> >> >> > On Mon, Sep 15, 2008 at 2:05 PM, dzizes wrote:
> >> >> >> >> > > Hi,
> >> >> >> >> > > I've installed mapserver on Debian (lenny
> distribution).
> >> >> >> >> > > I've managed to create mapfile based on shp data and
> >> >> >> >> > > successfully send a wms request to get a map. I seems
> >> >> >> >> > > that mapserver works fine.
> >> >> >> >> > > I've also installed oracle-ex and I can connect to my
> >> >> >> >> > > Oracle via sqlplus.
> >> >> >> >> > > However, when I request wms (to a map file pointing to
> >> >> >> >> > > Oracle10g) I
> >> >> >> >> > > receive
> >> >> >> >> > > the following:
> >> >> >> >> > > msDrawMap(): Image handling error. Failed to
> draw layer
> >> >> >> >> > > named 'test'.
> >> >> >> >> > > msOracleSpatialLayerOpen(): OracleSpatial error.
> >> >> >> >> > > OracleSpatial
> >> >> >> >> > > is
> >> >> >> >> > > not
> >> >> >> >> > > supported
> >> >> >> >> > > I've found that I need OCI installed and configured
> >> >> >> >> > > properly, but there is no clear tutorial.
> >> >> >> >> > > Please provide me a some step by step guide.
> >> >> >> >> > > Greets,
> >> >> >> >> > > Michal
> >> >> >> >> > > View this message in context:
> http://www.nabble.com/Debian-Oracle10g-OCI-tp19491636p1949
> >> >> >> >> > 1636.html
> >> >> >> >> > > Sent from the Mapserver - User mailing list
> archive at
> >> >> >> >> > > Nabble.com.
> >> >> >> >> > > _______________________________________________
> >> >> >> >> > > mapserver-users mailing list
Type: application/x-pkcs7-signature
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080916/667b7a05/smime-0001.bin
