[mapserver-users] KML for WMS Service
David Martinez Morata damarmo at gmail.com
Thu Sep 25 08:47:54 EDT 2008
Thanks for all your answeres!
I go to start testing with this information!
Thanks
2008/9/23 Carlos Ruiz <boolean10001 at yahoo.com>
> All,
> PostgreSQL can output as KML using the AsKML function. Hope this helps you
> to, at
> least, generate KML files.
> *IC Carlos Ruiz*
> --- On *Tue, 9/23/08, Bob Basques <Bob.Basques at ci.stpaul.mn.us>* wrote:
> From: Bob Basques <Bob.Basques at ci.stpaul.mn.us>
> Subject: Re: [mapserver-users] KML for WMS Service
> To: damarmo at gmail.com, mapserver-users at lists.osgeo.org
> Date: Tuesday, September 23, 2008, 7:48 AM
> All,
> I don't think I'm answering your question directly, but I've
> learned a few things about how Google earth imports WMS data directly, and that
> in turn showed me how to
>  export the layers from Google Earth into KML.  So now I
> can write the appropriate KML output.
> GE will import WMS services directly, but it's user interface leave a bit
> to be desired on the operational side.  I've been toying around with the
> same ideas though, where MapServer provides the result as a KML for GE use.
> So, my next step would be to make use of a MapServer template to generate the
> KML code (using the WMS export from GE as a starting point).  But this is where
> I stopped in the steps, got other more pressing stuff at the moment.
> bobb
> >>> "David Martinez Morata" <damarmo at gmail.com>
> 09/23/08 4:00 AM >>>
> Hi list.
> I just a little question.
> How I can create a KML file to show my WMS server in Google Earth?
> Thanks
> mapserver-users mailing
>  list
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080925/1f4452d5/attachment.html
