[mapserver-users] How to pimp WMS meta information?
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Fri Sep 26 07:31:17 EDT 2008
> -----Original Message-----
> From: Barend Kobben [mailto:kobben at itc.nl]
> Sent: 26 September, 2008 3:32 AM
> To: Jochen Topf
> Cc: Kralidis,Tom [Burlington]; Markus Spring; Mapserver-users
> Subject: Re: [mapserver-users] How to pimp WMS meta information?
> Ah, that might be true, never tried it. I just followed up on
> the comment about using mapscript to alter the
> Getcapabilities.xml, and reminded you that the
> <VendorSpecificCapabilities /> element would be the place to
> go if you don't want a Validator to choke on the xml you've created...
> Barend
Both ways work and are valid when tested in various XML validators.
You can use VendorSpecificCapabilities, yes, but the extra info, which,
from this thread, appears to be on a per-layer basis, would have to be
enclosed within the VendorSpecificaCapabilities tag, with the correct
ELEMENT defitions within the DOCTYPE.
http://wiki.osgeo.org/wiki/WMS_Tiling_Client_Recommendation#Example_Vend
orSpecificCapabilities exemplifies this capability. Here's an example
per this thread:
<VendorSpecificCapabilities>
<AncillaryInformation>
<LayerProperty layer="foo"
name="WMS_SHOW_QUERY_IN">large_popup</LayerProperty>
</AncillaryInformation>
</VendorSpecificCapabilities>
...or something like that.
To confirm, you cannot set something like this from within the mapfile
> On 26-09-08 09:27, "Jochen Topf" <jochen at remote.org> wrote:
> > On Fri, Sep 26, 2008 at 09:05:06AM +0200, Barend Kobben wrote:
> >> FYI, the valid way to extend the GetCapabilities is to use the
> >> <VendorSpecificCapabilities /> element. (See the WMS spec
> on the OGC
> >> pages
> >> www.opengeospatial.org)
> > And I'd rather use that, but as far as I know you can't set
> this from
> > a Mapserver map file?
> > Jochen
> International Institute for Geo-Information Science and Earth
> Observation (ITC) Chamber of Commerce: 410 27 560
> E-mail disclaimer
> The information in this e-mail, including any attachments, is
> intended for the addressee only. If you are not the intended
> recipient, you are hereby notified that any disclosure,
> copying, distribution or action in relation to the content of
> this information is strictly prohibited. If you have received
> this e-mail by mistake, please delete the message and any
> attachment and inform the sender by return e-mail. ITC
> accepts no liability for any error or omission in the message
> content or for damage of any kind that may arise as a result
> of e-mail transmission.
