[mapserver-users] Mapserver returns part of an image and then
crashes
Nelson Correia
nelsonwc7 at hotmail.com
Fri Apr 24 13:28:53 EDT 2009
I am using ms4w 2.3.1.
Unfortunately it is a large data set and a huge map file, that I am not able to send, sorry.
Thanks,
Nelson
Date: Fri, 24 Apr 2009 19:20:44 +0200
Subject: Re: [mapserver-users] Mapserver returns part of an image and then crashes
To: nelsonwc7 at hotmail.com
CC: mapserver-users at lists.osgeo.org
Which binaries are you using?
Could you provide the sample data with a mapfile to repoduce it?
Best regards,
Tamas
2009/4/24 Nelson Correia <nelsonwc7 at hotmail.com>
I am using mapserver on windows, and recently, after a few changes in my configuration, it started crashing (only for some bounding boxes - some areas of the map are returned without problem), without returning an error message. It returns only part of the image, but then the mapserver process crashes with the following information:
Problem signature:
Problem Event Name: APPCRASH
Application Name: mapserv.exe
Application Version: 0.0.0.0
Application Timestamp: 4935ad86
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a783
Exception Code: c0000005
Exception Offset: 0002f8f4
OS Version: 6.0.6001.2.1.0.272.7
Locale ID: 2070
Additional Information 1: c997
Additional Information 2: ae645009e6c492243309385fb187f9cb
Additional Information 3: 8219
Additional Information 4: b67578da7791af77bcf37b260b2c58a9
I reverted the changes I've made to a configuration that worked before, but I am no longer able to run it properly, it crashes all the time for certain zones of the map.
Any ideas?
Thanks,
Nelson
Get news, entertainment and everything you care about at Live.com. Check it out!
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
_________________________________________________________________
More than messages–check out the rest of the Windows Live™.
http://www.microsoft.com/windows/windowslive/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090424/75683db1/attachment.html
