[mapserver-users] Problem using getShape with MsSql2008
(Mapscript C#)
Paul james
pauljame at gmail.com
Wed Aug 5 16:44:31 EDT 2009
I´ll check...
But the same layer/id worked fine using Postgis... So I should be a bug...
Paul
On Wed, Aug 5, 2009 at 5:38 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Hi,
> I think you should check the sql statement submitted by the driver by using
> the SQL Profiler. I suspect no records have been retrieved during the fetch.
> Best regards,
> Tamas
> 2009/8/5 Paul james <pauljame at gmail.com>
>> Hello guys...
>> That code is working fine with Postgis:
>> _layer.open();
>> var _shape = new shapeObj((int)_layer.type);
>> _layer.getShape(_shape, 0, __id.ToInt32());
>> The _shape.bounds are all -1 using MsSql2008 ...
>> Any idea?
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090805/186e9789/attachment.html
