[mapserver-users] Problem using getShape with MsSql2008 (Mapscript C#)
Paul james pauljame at gmail.com
Thu Aug 6 10:33:54 EDT 2009
Just an update...
The shape values are all there... The only thing is wrong is the bounds (-1)
On Wed, Aug 5, 2009 at 5:44 PM, Paul james <pauljame at gmail.com> wrote:
> I´ll check...
> But the same layer/id worked fine using Postgis... So I should be a bug...
> Paul
> On Wed, Aug 5, 2009 at 5:38 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Hi,
>> I think you should check the sql statement submitted by the driver by
>> using the SQL Profiler. I suspect no records have been retrieved during the
>> fetch.
>> Best regards,
>> Tamas
>> 2009/8/5 Paul james <pauljame at gmail.com>
>>>  Hello guys...
>>> That code is working fine with Postgis:
>>> _layer.open();
>>> var _shape = new shapeObj((int)_layer.type);
>>> _layer.getShape(_shape, 0, __id.ToInt32());
>>> The _shape.bounds are all -1 using MsSql2008 ...
>>> Any idea?
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090806/f590b143/attachment.html
