[mapserver-users] Extracting X,Y from MULTIPOINT data
Suman Chatterjee
schatterjee at addisontx.gov
Mon Aug 10 11:04:38 EDT 2009
Hi Andy,
Thanks for your help. Actually, I am having both point and multipoint
data in the same table which I got through road intersections by
applying ST_intersection.
I am using this function for extracting the coordinates from the POINT
data.
Select distinct
x(geometryn(multi((st_intersection)),1)),y(geometryn(multi((st_intersect
ion)),1)),c,d from (select
ST_intersection(a.the_geom,b.the_geom),a.fname as c,b.fname as d from
roads1 as a, roads1 as b where a.fname<>b.fname and
ST_intersects(a.the_geom,b.the_geom) as drfe
But I am not getting the X,Y for the multipoint data. I require X,Y for
all the points within the multipoint set.
I can extract the multipoints from the whole by
Create table ex_intersects as (select
Select st_intersection from ex_intersects where
geometrytype(ST_intersection)='MULTIPOINT'
I tried with St_astext but it is giving the set of multipoints. But I
want the X,Y for all the points within the multipoint geometry.
How to do that?
Thanks
Suman
-----Original Message-----
Sent: Monday, August 10, 2009 8:52 AM
To: Suman Chatterjee
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Extracting X,Y from MULTIPOINT data
Suman Chatterjee wrote:
> Hi all,
> I have some multipoint data in postgis that I got from street
> intersections. But I am not able to extract the X,Y coordinates from
the
> MULTIPOINT data.
> Is there any function in postgis by which I can extract the X,Y point
> data from them?
> Please help!
> Thanks,
> Suman
Yes. Are you looking for all points? Just the first? Some subset?
How do you want to see it?
Did you try ST_AsText(col)?
There is also ST_NumPoints(geometry) and ST_PointN(geometry,integer) if
you want to look at them individually. An example of what youd like to
see, or what you are trying to do might be helpful.
More functions here:
http://postgis.refractions.net/documentation/manual-1.3/ch06.html
-Andy
This e-mail and any files or attachments transmitted with it contains Information that is confidential and privileged. This document may contain Protected Health Information (PHI) or other information that is intended only for the use of the individual(s) and entity(ies) to whom it is addressed. If you are the intended recipient, further disclosures are prohibited without proper authorization. If you are not the intended recipient, any disclosure, copying, printing, or use of this information is strictly prohibited and possibly a violation of federal or state law and regulations. If you have received this information in error, please delete it and notify Hamid Khaleghipour at 972-450-2868 immediately. Thank you.
