[mapserver-users] Extracting X,Y from MULTIPOINT data
Andy Colson
andy at squeakycode.net
Mon Aug 10 11:27:22 EDT 2009
> -----Original Message-----
> From: Andy Colson [mailto:andy at squeakycode.net]
> Sent: Monday, August 10, 2009 8:52 AM
> To: Suman Chatterjee
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Extracting X,Y from MULTIPOINT data
> Suman Chatterjee wrote:
>> Hi all,
>> I have some multipoint data in postgis that I got from street
>> intersections. But I am not able to extract the X,Y coordinates from
> the
>> MULTIPOINT data.
>> Is there any function in postgis by which I can extract the X,Y point
>> data from them?
>> Please help!
>> Thanks,
>> Suman
> Yes. Are you looking for all points? Just the first? Some subset?
> How do you want to see it?
> Did you try ST_AsText(col)?
> There is also ST_NumPoints(geometry) and ST_PointN(geometry,integer) if
> you want to look at them individually. An example of what youd like to
> see, or what you are trying to do might be helpful.
> More functions here:
> http://postgis.refractions.net/documentation/manual-1.3/ch06.html
> -Andy
> Hi Andy,
> Thanks for your help. Actually, I am having both point and multipoint
> data in the same table which I got through road intersections by
> applying ST_intersection.
> I am using this function for extracting the coordinates from the POINT
> data.
> Select distinct
> x(geometryn(multi((st_intersection)),1)),y(geometryn(multi((st_intersect
> ion)),1)),c,d from (select
> ST_intersection(a.the_geom,b.the_geom),a.fname as c,b.fname as d from
> roads1 as a, roads1 as b where a.fname<>b.fname and
> ST_intersects(a.the_geom,b.the_geom) as drfe
> But I am not getting the X,Y for the multipoint data. I require X,Y for
> all the points within the multipoint set.
> I can extract the multipoints from the whole by
> Create table ex_intersects as (select
> Select st_intersection from ex_intersects where
> geometrytype(ST_intersection)='MULTIPOINT'
> I tried with St_astext but it is giving the set of multipoints. But I
> want the X,Y for all the points within the multipoint geometry.
> How to do that?
> Thanks
> Suman
Wow, you are a lot deeper into postgis than I am, not sure if I'll be
any help.
Question: ST_intersection(a.the_geom,b.the_geom) returns a multipoint?
Then x(geometryn(multi((st_intersection)),1)) would return just the x
coord of the first point?
but you want the x coord of all the points? (yes, y too, I'm just
trying to break it down to understand)
-Andy
