[mapserver-users] Transparency of SLD-Layers
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue Aug 11 17:33:31 EDT 2009
Hi There,
Maybe snippets of the map file/sld and a grab of the images you are
getting would help to understand better the issues you are facing.
regards,
Sebastian Luhmer wrote:
> Hi List,
> I have used SLD to style some Layers of a WebGIS. Now, the Layers wich
> are styled according to the SLD overlay all the other active Layers that
> you can just see the SLD-Layer.
> I deleted the fill-opacity paramter from the SLD and tried to regulate
> the transparency over the Opacity-Parameter of the Mapfile. The effect
> was, that I could influence the Opacity of the layer, but when set to
> full transparency, the layers is not visible any more and it seems, that
> a white layer is already there and overlays the rest.
> I hope I could explain my problem understandingly. Does anybody have an
> idea or a hint how I can solve that problem?
> Best regards, Sebastian!
> Sebastian Luhmer
> Student assistant
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.: +49 (0) 228 - 73-1793
> FAX: +49 (0) 228 - 73-1889
> E-Mail: sluhmer at uni-bonn.de
> Web: http://www.coffee.uni-bonn.de
> http://www.zef.de
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
