[mapserver-users] map not available over the Lan or internet
sunny74 sb.ray at hotmail.com
Wed Aug 12 09:15:26 EDT 2009
Your suggestion worked.
So in this case it was apache not configured properly so as to get the
response from mapserver.
Thanks a million!!!
Rahkonen Jukka wrote:
> Hi,
> I am not sure what you mean with "map is not displayed". Do you mean
> that Mapserver seem to work normally but it returns an error or blank
> map, or is it impossible to reach Mapserver at all? If the latter, does
> your http server listen to the requested address? If MS4W package is
> used it is controlled in the D:\ms4w\Apache\conf\httpd.conf file.  There
> should read
> Listen 172.16.128.173:8085
> -Jukka Rahkonen-
> sunny74 wrote:
>> Hi,
>> I am displaying map using mapserver and openlayers in
>> aspx(ASP.NET) page.
>> But problem is that the map is displayed only on local
>> machine and not from a remote machine on the Lan or Internet.
>> On doing some r&D i found that if the url is given as in a
>> local machine i.e
>> http://localhost:8085/cgi-bin/mapserv.exe?map=WR_Shape/wrmap.m
>> ap&mode=map
>> Then map is displayed.
>> But if it is given like this,
>> http://172.16.128.173:8085/cgi-bin/mapserv.exe?map=WR_Shape/wr
>> map.map&mode=map
>> then it is not.
>> So how can I get mapserver to display map with IP.
>> Thanks for your replies.
>> View this message in context:
>> http://n2.nabble.com/map-not-available-over-the-Lan-or-interne
>> t-tp3429997p3429997.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://n2.nabble.com/map-not-available-over-the-Lan-or-internet-tp3429997p3430618.html
