[mapserver-users] map not available over the Lan or internet
sunny74
sb.ray at hotmail.com
Wed Aug 12 09:21:03 EDT 2009
Hi Adrian,
I did as u suggested and next to port 8085 I see SubranilBasu:0 LISTENING
and not 0.0.0.0 or 127.0.0.1
as u have stated.
I don't understand the terms "listening on all interfaces" and "listening
only on loopback".Could u pls explain them.
Thanks for your reply.
Regards.
Adrian Popa wrote:
> Make sure your server listens on all interfaces, not only on loopback.
> You need to check apache's config for this and restart the server.
> Also, you can do netstat -a (I think) on your windows system and look
> for your port (8085). If next to it you see 0.0.0.0, it means the server
> is listening on all interfaces. If you see 127.0.0.1, it means the
> server is listening only on loopback.
> Good luck.
> sunny74 wrote:
>> Hi,
>> I am displaying map using mapserver and openlayers in aspx(ASP.NET) page.
>> But problem is that the map is displayed only on local machine and not
>> from
>> a remote machine on the Lan or Internet.
>> On doing some r&D i found that if the url is given as in a local machine
>> i.e
>> http://localhost:8085/cgi-bin/mapserv.exe?map=WR_Shape/wrmap.map&mode=map
>> Then map is displayed.
>> But if it is given like this,
>> http://172.16.128.173:8085/cgi-bin/mapserv.exe?map=WR_Shape/wrmap.map&mode=map
>> then it is not.
>> So how can I get mapserver to display map with IP.
>> Thanks for your replies.
> Adrian Popa
> NOC Division
> Network Engineer
> Divizia Centrul National de Operare Retea
> Departament Transport IP & Metro
> Compartiment IP Core & Backbone
> Phone: +40 21 400 3099
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/map-not-available-over-the-Lan-or-internet-tp3429997p3430637.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
