[mapserver-users] Postgis tile index not working
Nelson Correia
nelsonwc7 at hotmail.com
Sat Aug 29 13:46:55 EDT 2009
I forgot saying that the bbox column of table shapes is in projection 4326 and my image files are PNGs (my mapserver is supporting PNG).
Nelson
To: mapserver-users at lists.osgeo.org
Date: Sat, 29 Aug 2009 17:11:59 +0000
Subject: [mapserver-users] Postgis tile index not working
I'm trying to use a postgis layer as tile index of a raster layer and can't get it working.
Here are the layers I'm using:
LAYER
NAME "layer_tindex"
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost port=5432 dbname=mydb user=myuser password=mypwd"
DATA "bbox from shapes"
CLASS
STYLE
OUTLINECOLOR 0 0 0
END
END
END
LAYER
NAME "layer_raster"
TYPE RASTER
STATUS DEFAULT
DUMP TRUE
TILEINDEX "layer_tindex"
TILEITEM "image_path"
PROJECTION
"init=epsg:4326"
END
END
When I make a request to Mapserver, everything gets into the image, except the images from the "layer_raster" layer. I can even see the bboxes if I turn on the layer "layer_tindex".
I can't find much documentation about this integration between Mapserver and Postgis, so tell me if I'm making some mistake.
By the way, I'm doing this with a Mapserver 5.2.1.
Thanks in advance,
Nelson
_________________________________________________________________
Share your memories online with anyone you want.
http://www.microsoft.com/middleeast/windows/windowslive/products/photos-share.aspx?tab=1
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090829/4078b7d9/attachment.html
