[mapserver-users] mapscript does not use GRID information when
reprojecting rect object
francesco
francesco.pirotti at unipd.it
Tue Dec 8 05:04:49 EST 2009
Hello I do not know if this it the right list to post, but I was
wandering if any of you had trouble when using the "project()" function
in mapscript (PHP). It does not use the grid file which is stated in the
EPSG line in the epsg file inside the ...proj/nad directory.
Reprojection of the map is wonderful, uses the grids, but script
reproject of a rectangle object does not make use of the grids. I made
sure of course that the epsg file which is read is the one I modified.
Anyone had the same problem?
Cheers,
*Francesco Pirotti*
Dep. TESAF
CIRGEO – Interdepartmental Research Center on Cartography Photogrammetry
Remote Sensing and G.I.S.
University of Padova
Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
Phone: +39 049 827 2710
Phone: +39 349 55 39 261
