[mapserver-users] make error - version 5.6.0-rc1 - /usr/bin/ld: cannot find -lxslt
Ted Spradley tspradley at snoogems.com
Fri Dec 11 12:55:24 EST 2009
Thanks Alan, and others.  I realize my server admin skills are lacking.
So, file.conf should be named 'lpam.conf' or 'libpam.conf'?  (tried both, then ldconfig as root ... still the same error)
Ted S.
  ----- Original Message -----
  To: Ted Spradley
  Sent: Friday, December 11, 2009 10:27 AM
  Subject: Re: [mapserver-users] make error - version 5.6.0-rc1 - /usr/bin/ld: cannot find -lxslt
  You could simply add the path to ldconfig. Add a file.conf in
  /etc/ld.so.conf.d/ which contains only a line with: /lib/
  and type "ldconfig" as root.
  Alan
  On December 11, 2009 11:08:59 am Ted Spradley wrote:
  > Stephen Woodbridge wrote:
  > > http://www.google.com/#hl=en&source=hp&q=fedora+7+libpam
  > > -Steve
  > Not having libpam doesn't appear to be the issue.  It just can't find it.
  > /usr/bin/ld: cannot find -lpam
  > # locate libpam
  > /lib/libpam.so.0
  > /lib/libpam.so.0.81.6
  > /lib/libpam_misc.so.0
  > /lib/libpam_misc.so.0.81.2
  > /lib/libpamc.so.0
  > /lib/libpamc.so.0.81.0
  > /root/psa/PSA_8.4.0/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-8.4.0-
  > fc7.build84080425.19.i586.rpm
  >  /root/psa/PSA_9.2.3/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-9.2.3
  > -fc7.build92091015.22.i586.rpm
  >  /swsoft/PSA_8.3.0/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-8.3.0-f
  > c7.build83071218.19.i586.rpm
  > Is there any way to feed make the path for this library?
  > Thanks, Ted S.
  Alan Boudreault
  Mapgears
  http://www.mapgears.com
  mapserver-users mailing list
  [hidden email]
  http://lists.osgeo.org/mailman/listinfo/mapserver-users
  View message @ http://n2.nabble.com/make-error-version-5-6-0-rc1-usr-bin-ld-cannot-find-lxslt-tp4148052p4152220.html
  To unsubscribe from Re: make error - version 5.6.0-rc1 - /usr/bin/ld: cannot find -lxslt, click here.
View this message in context: http://n2.nabble.com/make-error-version-5-6-0-rc1-usr-bin-ld-cannot-find-lxslt-tp4148052p4152695.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091211/227881da/attachment.html
