[mapserver-users] shapefile manipulation
sunny74
sb.ray at hotmail.com
Wed Dec 23 00:23:15 EST 2009
I have got several shapefiles from which I am able to display map using
mapserver.
But the problem is that it has a srid value of -1 i.e no projection.
As a result of this several functionalities which uses geometry are not
working.
I think the default srid value is 4326.Pls confirm.
I want to convert the srid value from -1 to 4326.
How can I do this using QGIS?
I know this is possible using GEOMEDIA Web 6.0.
If anybody has any idea or tutorial regarding .shp manipulation using
Geomedia pls send it across.
Thanks for ur replies.
sunny74
View this message in context: http://n2.nabble.com/shapefile-manipulation-tp4207328p4207328.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
