[mapserver-users] symbol problem
Fawcett, David
David.Fawcett at state.mn.us
Mon Feb 9 11:59:59 EST 2009
Valeria,
It would be useful if you provided more information. What version of MapServer are you using? What were you expecting to see?
Because you are setting your symbol angle to 0, I am guessing that you want all of the arrows to point to the top of the map.
I am aware of a bug in AGG rendering where TrueType symbols are not corrrectly rotated (fixed in trunk), but I haven't seen a problem with pixmap symbols.
In the symbol block of your layer, try commenting out the SIZE property. I think that you really just want your pixmap symbol to be displayed in its native size.
Also, in your symbol definition at the end of your map file, try changing the value of GAP from -50 to 50.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Valeria Muñoz
Sent: Monday, February 09, 2009 6:39 AM
To: mapserver-users
Subject: [mapserver-users] symbol problem
Hi
I have problems with displaying symbols,I can not give the correct orientation-... do you know why does not work with this configuration?
attached image of my problem
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB #RGBA transparente
EXTENSION "png"
FORMATOPTION "TRANSPARENT=OFF"
FORMATOPTION "INTERLACE=ON"
END
LAYER
NAME 'calle'
MAXSCALE 5000
TYPE LINE
DATA 'calle.shp'
METADATA
'wms_title' 'calle'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
#LABELITEM 'ONEWAY'
CLASS
EXPRESSION ('[HWYLEVEL]' = '4' and '[ONEWAY]'='0')
#TEXT (<->)
#NAME 'calle'
STYLE
SYMBOL 'flecha_ambos'
SIZE 13
ANGLE 0
#OUTLINECOLOR 161 189 196
#COLOR 0 0 0
END
LABEL
TYPE truetype
FONT 'georgia'
SIZE 6
ANTIALIAS TRUE
COLOR 156 0 0
ANGLE FOLLOW
#MINDISTANCE -1
#MINFEATURESIZE -1
OFFSET 5 0
FORCE FALSE
POSITION CC
BUFFER 10
PARTIALS FALSE
END
END
END
SYMBOL
NAME "flecha_ambos"
TYPE PIXMAP
IMAGE "C:/ms4w/Apache/htdocs/mapFile/mapas/etc/icons/arrow_left_right.png"
GAP -50
END
RG
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090209/c9bfe545/attachment.html
