[mapserver-users] How can I do a SQL text comparison in a
mapfile?
thomas bonfort
thomas.bonfort at gmail.com
Thu Feb 12 16:22:06 EST 2009
I don't see why you're a problem with that query string. From my
experience, there's a limitation when you need to mix single and
double quotes inside the sql expression.
eg:
DATA "way from (select way,osm_id ,leisure , landuse, name from
osm_polygon where leisure='park' or leisure='golf_course' or
landuse='recreation_ground' or landuse='cemetery') as foo using unique
osm_id using srid=900913"
works fine.
Travis, could you post your exact data statement, so we can check if
your problem isn't elsewhere?
regards,
thomas
On Thu, Feb 12, 2009 at 20:45, Travis Kirstine <traviskirstine at gmail.com> wrote:
> The following line does not work and I think it has something to do
> with the single quotes. When I use double quotes Postgres thinks I'm
> referring to a column name. Is there a way to escape the single
> quotes?
> DATA "geom from (select id as oid, geom from some_table where
> some_field = 'some_string') as myquery using SRID=-1"
> The following line works because I'm doing a numeric comparison.
> some_field_number = 99) as myquery using SRID=-1"
> Travis K.
> Toronto, Canada
> "She knows there's no success like failure
> And that failure's no success at all."
> -Bob Dylan-
> mapserver-users at lists.osgeo.org
