[mapserver-users] How can I do a SQL text comparison in a mapfile?
Travis Kirstine traviskirstine at gmail.com
Thu Feb 12 14:45:28 EST 2009
The following line does not work and I think it has something to do
with the single quotes.  When I use double quotes Postgres thinks I'm
referring to a column name.  Is there a way to escape the single
quotes?
DATA "geom from (select id as oid, geom from some_table where
some_field = 'some_string') as myquery using SRID=-1"
The following line works because I'm doing a numeric comparison.
some_field_number = 99) as myquery using SRID=-1"
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
