[mapserver-users] Problem with loading map file using C# map
script
Tamas Szekeres
szekerest at gmail.com
Wed Feb 18 14:02:45 EST 2009
Would you send me the files privately for the meantime?
Tamas
2009/2/18 Murty Maganti <MMaganti at oriongis.com>
> Hi
> I have posted the test application. But the email is waiting for approval
> of moderator (as the attachment size is 75 KB and I think allowed is only 40
> KB).
> Thanks
> Murty
> *From:* Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* Tuesday, February 17, 2009 6:33 PM
> *To:* Murty Maganti
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Problem with loading map file using C#
> map script
> Hmmm. I haven't found such an issue before.
> If you could post an example that would be helpful to reproduce this.
> Best regards,
> Tamas
> Hi
> I have a issue loading a map file through map script and need help.
> I have two map info (tab) files with same name but in two different
> folders. I have two map files each containing each layer. I am loading these
> map files using C# map script (each map file is loaded in to a separate
> mapObj on a separate thread). At run time, when I debug the second mapObj,
> the layer has items (layerObj.getItem()) from the first layer loaded by the
> first map file. I verified 'shapepath' on mapObj and it is pointing to
> correct path. There is nothing wrong there. I am surprised how is it caching
> the item info, just by the file name (file name is same but they are
> completely from different folders).
> When I load the map file one more time (again a different .Net thread, it
> shows up correct fields).
> Within my app (Asp.Net), I can consistently replicate this.
> Thanks
> Murty
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090218/30de27b3/attachment.html
