[mapserver-users] Problem with loading map file using C# map
script
Murty Maganti
MMaganti at oriongis.com
Wed Feb 18 14:36:19 EST 2009
Hi
Tried few times before but that is bouncing with following message
Your message did not reach some or all of the intended recipients.
Subject: RE: [mapserver-users] Problem with loading map file
using C# map script
The following recipient(s) cannot be reached:
'Tamas Szekeres' on 2/18/2009 2:35 PM
There was a SMTP communication problem with the recipient's
email server. Please contact your system administrator.
<mail.oriongis.com #5.5.0 smtp;552-5.7.0 Our system detected
an illegal attachment on your message.>
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Wednesday, February 18, 2009 2:03 PM
To: Murty Maganti
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Problem with loading map file using C#
map script
Would you send me the files privately for the meantime?
Tamas
2009/2/18 Murty Maganti <MMaganti at oriongis.com>
Hi
I have posted the test application. But the email is waiting for
approval of moderator (as the attachment size is 75 KB and I think
allowed is only 40 KB).
Thanks
Murty
Sent: Tuesday, February 17, 2009 6:33 PM
To: Murty Maganti
map script
Hmmm. I haven't found such an issue before.
If you could post an example that would be helpful to reproduce this.
Best regards,
Tamas
Hi
I have a issue loading a map file through map script and need help.
I have two map info (tab) files with same name but in two different
folders. I have two map files each containing each layer. I am loading
these map files using C# map script (each map file is loaded in to a
separate mapObj on a separate thread). At run time, when I debug the
second mapObj, the layer has items (layerObj.getItem()) from the first
layer loaded by the first map file. I verified 'shapepath' on mapObj and
it is pointing to correct path. There is nothing wrong there. I am
surprised how is it caching the item info, just by the file name (file
name is same but they are completely from different folders).
When I load the map file one more time (again a different .Net thread,
it shows up correct fields).
Within my app (Asp.Net), I can consistently replicate this.
Thanks
Murty
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090218/c71d3c55/attachment.html
