[mapserver-users] Status on ticket 2582?
Martin Kofahl
m.kofahl at gmx.net
Sat Feb 21 02:57:31 EST 2009
I think the second patch for ticket 1952 already covers some of these
issues for the wms service (one can easily change ows_service to
ows_hidden_layer -- I think 'hidden' makes even more sense than 'ignore'):
> 1) The hiding mechanism must not interfere with which layers that
> actually are rendered (turned on).
... only suppresses the capabilities output.
> 2) What will happen if the hidden layer is inside a GROUP?
... the single layer is hidden
> 3) What will happen if all layers inside a GROUP is hidden?
... as far I remember, the mentioned patch currently hides the whole
group and its layers. In order to support grouped layers for different
resolutions, my workaround was to hide any layer in this group (hence no
capabilities) and to have a single not-grouped, not-hidden layer with
the name identical to the group name.
When all grouped layers are hidden and we decide to expose it as a sigle
layer as Pål suggests, the question is which metadata to use.
> 4) What will happen if the hidden layer is part of a group defined
> with the wms_layer_group metadata tag?
... should work similar to 2 und 3. But currently I have no idea what
the patch does with wms_layer_group layers.
Martin
paalkr wrote:
> Hi All!
> I glad this issue got some focus, and I must say that I was kind of
> surprised realizing that ticket 2582 only addressed the MapScript
> part. Anyway, I'm very glad that Jeff now proposes a final solution
> for this issue, that of course should be fixed in both cgi and
> MapScript, and for every service type.
> Jeffs proposal for a boolean metadata keyword, like ignore_layer
> sound OK, but maybe ows_ignore_layer is more appropriate as the layer
> obviously shall not be ignored, only the exposure in the
> GetCapabilities document. I think the following aspects are important
> to have in mind when resolving the issue:
> actually are rendered (turned on) . This has to be controlled as
> before by the STATUS, SCALE and DEPENDENCIES keywords. 2) What will
> happen if the hidden layer is inside a GROUP? 3) What will happen if
> all layers inside a GROUP is hidden? I would suggest that the group
> layer is exposed as a single layer, in this way you could have
> different resolution layers inside a GROUP and expose this as a
> single layer to the end user. Often the different resolution layers
> are only present to optimize rendering speed, and are not intended
> for the end user. 4) What will happen if the hidden layer is part of
> a group defined with the wms_layer_group metadata tag?
> Regards, Pål Kristensen
> Jeff McKenna wrote:
>> Alan Boudreault wrote:
>>> It could. By the fact that a status MS_DELETE can only be set
>>> through Mapscript, i've only added this part. I think the ticket
>>> have been open for that ? You could add a comment in the ticket
>>> to propose a specific mapfile setting.
>>> Alan
>> I've made a comment in that ticket, and I am proposing we finally
>> fix this through an old existing ticket
>> (http://trac.osgeo.org/mapserver/ticket/337).
>> -jeff
