[mapserver-users] Getting error while executing sample application
in FGS in fedora 7
Daniel Morissette
dmorissette at mapgears.com
Wed Jan 7 08:19:52 EST 2009
muzaffar hussain wrote:
> If i press the "Click Me" button it shows errors as
> _* loadWeb(): Unknown identifier. Parsing error near
> (/opt/fgs/www/htdocs/tmp/):(line 1)
Remove the hidden form parameter for map_web_imagepath in your
hello.html, it is redundant since the value is already set in your .map
file.
The reason for the error is that the syntax to set mapfile parameters
via the URL has changed in MapServer 5.0 and using "map_web_imagepath"
is no longer supported.
Daniel
Daniel Morissette
http://www.mapgears.com/
