[mapserver-users] website upgrade for older documentation
zach cruise
zachc1980 at gmail.com
Mon Jan 12 15:32:56 EST 2009
http://trac.osgeo.org/mapserver/ticket/2855
On 1/9/09, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Zach, et al,
> It might be possible to do something like you are suggesting going
> forward, as the documentation is been migrated into svn and should get
> tagged with each release we do. Since this was not done in the past it
> is unlikely that we can go backward in time with this type a scenario.
> I think it will be up to the doc and web team to look into doing
> something like this, but I believe the 1st step of having the docs in
> svn is the critical pieces to be able to do anything like this.
> I think you should write a ticket in the bug tracking system and then
> post the tick number so interested parties can sign up to be CC on it.
> Thanks,
> -Steve
> zach cruise wrote:
>> actually we just need to refer to old documentation for upgrading and
>> porting, thanks though. if possible, we prefer something like
>> http://www.mapserver.org/4.8/mapfile/map.html
>> http://www.mapserver.org/5.2/mapfile/map.html
>> much like
>> http://www.postgresql.org/docs/8.1/interactive/sql-select.html
>> http://www.postgresql.org/docs/8.1/static/sql-select.html
>> http://www.postgresql.org/docs/8.2/interactive/sql-select.html
>> http://www.postgresql.org/docs/8.2/static/sql-select.html
>> On Thu, Jan 8, 2009 at 2:31 PM, Dan Little <danlittle at yahoo.com> wrote:
>>> Zach,
>>> Not trying to be a pushy guy... but is there a feature missing in 5.0
>>> prevents you from upgrading?
>>> ----- Original Message ----
>>>> From: zach cruise <zachc1980 at gmail.com>
>>>> To: Jeff McKenna <jmckenna at gatewaygeomatics.com>
>>>> Cc: mapserver-users at lists.osgeo.org
>>>> Sent: Thursday, January 8, 2009 12:31:26 PM
>>>> Subject: Re: [mapserver-users] website upgrade for older documentation
>>>> thanks. any way to search 4.8 documentation? any one got archived copy
>>>> other than
>>>> http://web.archive.org/web/20060701050731/http://mapserver.gis.umn.edu/?
>>>> On Thu, Jan 8, 2009 at 12:21 PM, Jeff McKenna
>>>> wrote:
>>>>> zach cruise wrote:
>>>>>> On Wed, Jan 7, 2009 at 5:29 PM, zach cruise wrote:
>>>>>>> great website upgrade at http://www.mapserver.org/. how can i search
>>>>>>> for older documentation like with postgresql.org?
>>>>> The current (5.2.1) documents should have MapServer version references
>>>>> inside them for specific functionality (such as a specific mapfile
>>>>> parameter
>>>>> added in 5.0).
>>>>> -jeff
>>>>> Jeff McKenna
>>>>> FOSS4G Consulting and Training Services
>>>>> http://www.gatewaygeomatics.com/
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
