[mapserver-users] Sqlite / Spatialite as a layer
Richard Greenwood
richard.greenwood at gmail.com
Fri Jan 16 08:07:37 EST 2009
On Fri, Jan 16, 2009 at 2:57 AM, James Mapserver
<james.mapserver at gmail.com> wrote:
> Hi does anyone have any examples of using this ?
> I see that Sqlite is included as an option with OGR - but the only reference
> I can see is:
> http://www.gdal.org/ogr/drv_sqlite.html
> Does anyone have any examples of the layer statement needed in a mapserver
> .map file
> Also - can the spatialite extension be used at all ?
> It looks similar to PostGIS - and whilst not having all the power may have
> application for simpler datasets / setups where a full PostGIS install is
> not possible
### SQLite/SpatiaLite
CONNECTIONTYPE OGR
CONNECTION "/data/23_Sublette_GIS/sqlite/sublette.sqlite" # full
path to SQLite db file
DATA "ownership" # table in db file
The geometry must be in WKT format. You can import w/ GDAL like:
ogr2ogr -f "SQLite" -lco FORMAT=WKT dest.db source.shp source
Or import w/ SpatiaLite and the convert to WKT like:
sqlite> alter table ownership add column WKT_GEOMETRY;
sqlite> update ownership set WKT_GEOMETRY=astext(geom);
You don't do select statements like w/ PostGIS. Treat it like a shape
file and use FILTER and FILTERITEM.
Rich
Richard Greenwood
www.greenwoodmap.com
