[mapserver-users] Sqlite / Spatialite as a layer
James Perrins james.perrins at gmail.com
Fri Jan 16 09:30:49 EST 2009
Many thanks Richard,
I'll have a go with that.  If I understand you correctly the OGR
doesn't support Spatalite (hence the need for WKT) - but as you point
out you can use spatialite to generate the WKT
Best wishes
James
On Fri, Jan 16, 2009 at 1:07 PM, Richard Greenwood
<richard.greenwood at gmail.com> wrote:
> On Fri, Jan 16, 2009 at 2:57 AM, James Mapserver
> <james.mapserver at gmail.com> wrote:
>> Hi does anyone have any examples of using this ?
>> I see that Sqlite is included as an option with OGR - but the only reference
>> I can see is:
>> http://www.gdal.org/ogr/drv_sqlite.html
>> Does anyone have any examples of the layer statement needed in a mapserver
>> .map file
>> Also - can the spatialite extension be used at all ?
>> It looks similar to PostGIS - and whilst not having all the power may have
>> application for simpler datasets / setups where a full PostGIS install is
>> not possible
>   ### SQLite/SpatiaLite
>   CONNECTIONTYPE OGR
>   CONNECTION "/data/23_Sublette_GIS/sqlite/sublette.sqlite"  # full
> path to SQLite db file
>   DATA "ownership" # table in db file
> The geometry must be in WKT format. You can import w/ GDAL like:
>   ogr2ogr -f "SQLite" -lco FORMAT=WKT dest.db source.shp source
> Or import w/ SpatiaLite and the convert to WKT like:
>  sqlite> alter table ownership add column WKT_GEOMETRY;
>  sqlite> update ownership set WKT_GEOMETRY=astext(geom);
> You don't do select statements like w/ PostGIS. Treat it like a shape
> file and use FILTER and FILTERITEM.
> Rich
> Richard Greenwood
> www.greenwoodmap.com
> mapserver-users at lists.osgeo.org
Dr James Perrins
exeGesIS SDM Ltd
Great House Barn
New Street, Talgarth
Powys LD3 0AH.
Direct Line: 01646 686650
Tel: 01874 711145
Fax: 01874 711156
Email: JamesP at esdm.co.uk
This E-mail and any files transmitted with it are private and intended
solely for the use of the individual or entity to whom they are
addressed. If you are not the intended recipient, the E-mail and any
files have been transmitted to you in error and any copying,
distribution or other use of the information contained in them is
strictly prohibited.
Nothing in this E-mail message amounts to a contractual or other legal
commitment on the part of exeGesIS SDM Ltd unless confirmed by a
signed communication.
exeGesIS SDM Ltd will make every effort to keep its network free of
viruses. However, the recipient of this message will need to scan this
message, and any attachments, for viruses, as exeGesIS SDM Ltd can
take no responsibility for any computer virus that might be
transferred by this e-mail.
