[mapserver-users] dynamically added shapes and their values
Pietro Giannini
pgiannini at bytewise.it
Thu Jan 22 05:28:44 EST 2009
Dan,
I considered this solution, as well as (Steve) creating a layer for each
classification.
maybe you are right, despite I must to generate a different file for each
user-session: other garbage in tmp dir... :)
possibility of apply a style to a single feature can be a great
functionality for further releases...
what about the STYLEITEM?
http://mapserver.org/mapfile/layer.html?highlight=styleitem
http://mapserver.org/mapscript/mapscript.html?highlight=styleitem
thanks all
bye ..................pg
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
On Mer, Gennaio 21, 2009 22:09, Dan Little wrote:
> Totally spit balling...
> What about writing your layer to a temp. file that's KML/GML.
> The file size is small, it carries the attributes you want, and it's easy
> to write the file using anything that writes text files (presumable C#
> can write text files ... but I know Microsoft misses little details from
> time to time).
> Then write yourself a little mapfile you can open... maybe following this
> as a guide...
> http://mapserver.org/input/vector/gml.html
> -or-
> http://mapserver.org/input/vector/kml.html
> And just change "CONNECTION" using Mapscript to whatever the location of
> your newly created KML/GML file happens to be, then proceed with the
> processing.
> ----- Original Message ----
>> From: Steve Lime <Steve.Lime at dnr.state.mn.us>
>> To: Pietro Giannini <pgiannini at bytewise.it>;
>> mapserver-users at lists.osgeo.org
>> Sent: Wednesday, January 21, 2009 2:43:31 PM
>> Subject: Re: [mapserver-users] dynamically added shapes and their values
>> PG: At this point inline feature can carry no attributes and as a result
>> cannot
>> be
>> classified. So I don't think you're going to be able to make this work.
>> The work
>> around is to use separate layers for what would have been a class and
>> add
>> features to the appropriate layer.
>> Steve
>> >>> On 1/21/2009 at 10:29 AM, in message
>> <55312.89.97.235.106.1232555376.squirrel at localhost.localdomain>, "Pietro
>> Giannini" wrote:
>> > Hi all,
>> > I'm working to a c# asp.net project embedding a mapscript application.
>> > My attempt is to add dynamically features to a layer object and
>> classify
>> > them in different colors.
>> > The features are INLINE features: I don't add the features to the
>> source
>> > of the layer.
>> > I'm able to create different classes and styles in the layer, set a
>> field
>> > as classitem and set an EXPRESSION string to the class.
>> > I found the
>> > shapeObj.initValues(numOfFields)
>> > method, which cannot set the field names, only the number, and also
>> the
>> > shapeObj.setValue(indexOfField, valueAsString)
>> > for setting the value.
>> > Now I need a field name to set a CLASSITEM property of the layer!!!
>> > I found no methods to add a named field to the layer.
>> > Maybe I follow a wrong way...
>> > Someone has an idea?
>> > thanks in advance
>> > ...........................pg
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
