[mapserver-users] GDAL_WMS xml inline
Tamas Szekeres szekerest at gmail.com
Thu Jan 29 14:54:17 EST 2009
Frank,
It looks like the GDAL WMS driver does accept the XML strings directly,
however we may run into a limitation in the maximum length (1024) in the
MapServer GDAL driver since the connection string is handled as if it was a
filename in every case.
Best regards,
Tamas
2009/1/29 Frank Warmerdam <warmerdam at pobox.com>
> bartvde at osgis.nl wrote:
>> Hi list,
>> is it possible to use a GDAL_WMS XML config inline in a MAP file, just
>> like it is possible to use an ovf file inline?
> Bart,
> No, I do not believe so, though it would be relatively easy to modify the
> WMS driver to support this.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090129/5c6cfc77/attachment.html
