[Mapserver-users] programming with visual basic .net
Milo van der Linden mlinden at zeelandnet.nl
Thu Jul 2 17:38:43 EDT 2009
I do not want to be rude to the mapserver community, since I moved to
linux 2 years ago I have never abandonned it ;-) but...
If you want to create mapping applications from the dotnet framework,
you might want to consider sharpmap. I have had some really good
experience with their toolkit when I was still programming for windows:
http://sharpmap.codeplex.com/
Maybe it can be of use for you.
Kind regards,
Milo van der Linden
Tamas Szekeres wrote:
> Hi,
> You can use the MapScript C# wrapper to achieve the desired
> functionality according to the following steps:
> 1. Download the binary package which suits best to your compiler and
> architecture: http://vbkto.dyndns.org:1280/sdk/Default.aspx
> 2. Add reference to the mapscript_csharp.dll in your Visual Studio
> project.
> 3. Copy the dll-s from the /bin and /bin/ms/csharp directory into your
> target directory.
> 4. use the classes of the OSGeo.MapServer namespace to make up your
> application
> Refer to the following tutorial for more detailed information
> http://www.paolocorti.net/2006/09/20/mapserver-tutorial-for-c-mapscript-asp-net/
> Best regards,
> Tamas
> 2009/7/2 <youness.elmedraoui at somei.fr
> <mailto:youness.elmedraoui at somei.fr>>
>     Hello,
>     i'm a new member in this list and i have some questions.
>     i want to construct a web site with mapserver and programming with
>     visual basic .net (framework 2.0). what i need for that? there is
>     some dlls file to compile for work with mapscript vb .net?
>     help me plz. thanks
>     with best regards,
>     Youness ELMEDRAOUI
>     Les informations figurant sur cet e-mail ont un caractère
>     strictement confidentiel et sont exclusivement adressées au
>     destinataire mentionné ci-dessus.Tout usage, reproduction ou
>     divulgation de cet e-mail est strictement interdit si vous n'en
>     êtes pas le destinataire.Dans ce cas, veuillez nous en avertir
>     immédiatement par la même voie et détruire l'original. Merci
>     _______________________________________________
>     mapserver-users mailing list
>     mapserver-users at lists.osgeo.org
>     <mailto:mapserver-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapserver-users
