[Mapserver-users] programming with visual basic .net
Lewis Clark
lclark at genasys.com
Fri Jul 3 03:15:12 EDT 2009
We've successfully used SharpMap but I would be wary of choosing it today. The project seems to have lost its way after its creator Morten Nielsen left for ESRI. The last stable release, 0.9, is from 2006 when he was still with the project.
Regards,
Lewis.
-----Mensaje original-----
De: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] En nombre de Milo van der Linden
Enviado el: jueves, 02 de julio de 2009 23:39
Para: mapserver-users at lists.osgeo.org
Asunto: Re: [Mapserver-users] programming with visual basic .net
I do not want to be rude to the mapserver community, since I moved to
linux 2 years ago I have never abandonned it ;-) but...
If you want to create mapping applications from the dotnet framework,
you might want to consider sharpmap. I have had some really good
experience with their toolkit when I was still programming for windows:
http://sharpmap.codeplex.com/
Maybe it can be of use for you.
Kind regards,
Milo van der Linden
Tamas Szekeres wrote:
> Hi,
> You can use the MapScript C# wrapper to achieve the desired
> functionality according to the following steps:
> 1. Download the binary package which suits best to your compiler and
> architecture: http://vbkto.dyndns.org:1280/sdk/Default.aspx
> 2. Add reference to the mapscript_csharp.dll in your Visual Studio
> project.
> 3. Copy the dll-s from the /bin and /bin/ms/csharp directory into your
> target directory.
> 4. use the classes of the OSGeo.MapServer namespace to make up your
> application
> Refer to the following tutorial for more detailed information
> http://www.paolocorti.net/2006/09/20/mapserver-tutorial-for-c-mapscript-asp-net/
> Best regards,
> Tamas
> 2009/7/2 <youness.elmedraoui at somei.fr
> <mailto:youness.elmedraoui at somei.fr>>
> Hello,
> i'm a new member in this list and i have some questions.
> i want to construct a web site with mapserver and programming with
> visual basic .net (framework 2.0). what i need for that? there is
> some dlls file to compile for work with mapscript vb .net?
> help me plz. thanks
> with best regards,
> Youness ELMEDRAOUI
> Les informations figurant sur cet e-mail ont un caractère
> strictement confidentiel et sont exclusivement adressées au
> destinataire mentionné ci-dessus.Tout usage, reproduction ou
> divulgation de cet e-mail est strictement interdit si vous n'en
> êtes pas le destinataire.Dans ce cas, veuillez nous en avertir
> immédiatement par la même voie et détruire l'original. Merci
> <mailto:mapserver-users at lists.osgeo.org>
