[mapserver-users] Can't get JOIN to work with Postgis
Ganaël Jatteau
gju at galigeo.com
Fri Jul 3 03:37:13 EDT 2009
I'm trying to use the tag JOIN in a layer in order to join two tables in
POSTGIS.
The layer gets displayed on the map but it seems that the join is ignored (a
subset of the layer should be displayed normally after the join and when I
select some features I dont see the attributes from the join table).
BTW: I use MapServer 5.2.1 on Windows
Is there anything wrong with the layer that has been defined:
LAYER
CONNECTION "host=localhost user=scott dbname=basepiad password='tiger'
CONNECTIONTYPE POSTGIS
DATA "the_geom from dept_aquitaine using unique oid using SRID=27581"
CLASS
NAME "classe"
STYLE
ANGLE 360
COLOR 255 255 255
OPACITY 100
OUTLINECOLOR 180 180 180
SYMBOL 0
END
END
JOIN
NAME "test_join"
TABLE "webigeo.wap1"
FROM "code_depar"
TO "f0"
TYPE ONE-TO-ONE
END
NAME "departements_join"
STATUS ON
TEMPLATE "ttt"
TYPE POLYGON
UNITS METERS
END
Thanks in advance.
Ganaël
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090703/f72befe1/attachment.html
