[mapserver-users] Can't get JOIN to work with Postgis
Ganaël Jatteau
gju at galigeo.com
Fri Jul 3 05:18:15 EDT 2009
You're right, the two tables are not in the same schema but they have the
appropriate select rights.
Having a join defined in the data works fine:
DATA "the_geom from (SELECT dept_aquitaine.the_geom as the_geom, wap1.f0 as
name0, wap1.f1 as name1, dept_aquitaine.oid as oid from dept_aquitaine INNER
JOIN webigeo.wap1 on (dept_aquitaine.code_depar = wap1.f0)) as tmp using
SRID=27581"
However I would have preferred using a JOIN since it is easier to generate
in a program and more generic.
Cheers
Ganael
-----Message d'origine-----
De : Pavel Iacovlev [mailto:iacovlev.pavel at gmail.com]
Envoyé : vendredi 3 juillet 2009 10:22
À : Ganaël Jatteau
Objet : Re: [mapserver-users] Can't get JOIN to work with Postgis
wap1 is in webigeo schema and dept_aquitaine is in public schema ?
Try to do a simple SQL join query, first test in in pgsql and then
just paste it in your data sections, easier to debug.
SELECT dept_aquitaine.the_geom as the_geom, wap1.some_field as name
from dept_aquitaine
LEFT JOIN webigeo.wap1 on (dept_aquitaine.f0 = wap1.f0)
) as tmp using SRID=YOUR_SRID using unique YOUR_GID"
On Fri, Jul 3, 2009 at 10:37 AM, Ganaël Jatteau<gju at galigeo.com> wrote:
> Hi,
> I'm trying to use the tag JOIN in a layer in order to join two tables in
> POSTGIS.
> The layer gets displayed on the map but it seems that the join is ignored
(a
> subset of the layer should be displayed normally after the join and when I
> select some features I dont see the attributes from the join table).
> BTW: I use MapServer 5.2.1 on Windows
> Is there anything wrong with the layer that has been defined:
> LAYER
> CONNECTION "host=localhost user=scott dbname=basepiad password='tiger'
> CONNECTIONTYPE POSTGIS
> DATA "the_geom from dept_aquitaine using unique oid using SRID=27581"
> CLASS
> NAME "classe"
> STYLE
> ANGLE 360
> COLOR 255 255 255
> OPACITY 100
> OUTLINECOLOR 180 180 180
> SYMBOL 0
> END
> END
> JOIN
> NAME "test_join"
> TABLE "webigeo.wap1"
> FROM "code_depar"
> TO "f0"
> TYPE ONE-TO-ONE
> END
> NAME "departements_join"
> STATUS ON
> TEMPLATE "ttt"
> TYPE POLYGON
> UNITS METERS
> END
> Thanks in advance.
> Ganaël
> mapserver-users at lists.osgeo.org
http://iap.md, The future is open
