[mapserver-users] plotting points dynamically
Jay Kapalczynski
jkapalczynski at ci.maple-grove.mn.us
Mon Jul 6 11:30:46 EDT 2009
Suman
I am doing this another way.... Although I am using GeoMoose/MapServer...
I am using an OGR connection in my map file to connect to a MySQL database via a OVF file....this is plotting Points based on XY Coordinates, which is querying the database. I am would have to look up again what I am doing if you are interested in this.
Is this something like you are doing Bobb. I am not familiar with the Query/Render engine in map server.
Jay
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bob Basques
Sent: Tuesday, June 30, 2009 10:03 AM
To: Suman Chatterjee; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] plotting points dynamically
The best approach I can think of, would be to figure out how to add the points to the database in a dynamic method, and use MapServer as the Query/Render engine. This is how we do GPS location points for example. The points are loaded into the Database (POSTGIS) and simply (re)read as a display request by MapServer.
Just set up both sides, the Database and the MapServer connectivity to the database as two separate processes, and that should get you what you are after.
bobb
>>> "Suman Chatterjee" <schatterjee at addisontx.gov> wrote:
Hi all,
I am working on a project which requires adding points to a basic map dynamically. That means the basic map will be read from the map file. Then the points will be queried from a database preferably PostGreSQL and then plotted on the map. I cannot add the query to the map file because the points will be generated dynamically at regular intervals.
Is there any way I can do this in mapserver?
This e-mail and any files or attachments transmitted with it contains Information that is confidential and privileged. This document may contain Protected Health Information (PHI) or other information that is intended only for the use of the individual(s) and entity(ies) to whom it is addressed. If you are the intended recipient, further disclosures are prohibited without proper authorization. If you are not the intended recipient, any disclosure, copying, printing, or use of this information is strictly prohibited and possibly a violation of federal or state law and regulations. If you have received this information in error, please delete it and notify Hamid Khaleghipour at 972-450-2868 immediately. Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090706/0a42405f/attachment.html
